I am trying to use some of the IO pins of the dsPIC33FJ128GP802. The pins in question are RB8 thru RB11.
I have written a little program that reads the input value of one of those pins and outputs it to pin RA4.
All I get is straight 0, which ever of those pins I use.
If I use any PORTB pin from 7 down (i.e., the lower byte of the register), it functions perfectly.
I have scraped through the errata, and found nothing that has any bearing on this problem.
What am I missing?
Test program:
#include <p33Fxxxx.h>
_FWDT(FWDTEN_OFF)
_FOSCSEL(FNOSC_PRIPLL)
_FOSC(POSCMD_HS)
int main(void)
unsigned int x=0;
// Configure clock and PLL for 40 MIPS from 4MHz crystal
CLKDIVbits.DOZE = 0;
CLKDIVbits.DOZEN = 0;
CLKDIVbits.FRCDIV = 0;
CLKDIVbits.PLLPOST = 0;
CLKDIVbits.PLLPRE = 0;
PLLFBDbits.PLLDIV = 78;
// Disable the CCP output pins as per a bug mentioned in the errata.
// Should not apply to this case, but just to be sure...
CMCONbits.C1OUTEN=0;
CMCONbits.C2OUTEN=0;
// Disable all ADC pins (make them digital)
AD1PCFGL = 0xFFFF;
// Configure IO pins
TRISBbits.TRISB10=1; // RB10 Input
TRISAbits.TRISA4=0; // RA4 Output
while(1)
// Send input state to output pin
LATAbits.LATA4 = PORTBbits.RB10;
Other useful info:
Microchip Language Tool Shell Version v3_30 (Build date: Jun 21 2011).
The inputs are being driven by an Arduino, but using that, or hard-wiring to \$V_{LH}\$ or \$V_{LL}\$ makes no difference.
P.S. I am no newbie to PICs, having spent many hours on PIC16s and PIC18s, so don't bother with the "obvious" answers.
