I want to ask a question. I'm trying to simulate a cpu. I did my schema and basically there are two logical parts of the CPU.
The first part is composed of a FIFO buffer, Cache memory for instructions and a PC register.
I created architecture and entities for each of the 3 named elements.
Can I make one entity that contains all of these 3 entities and their architectures? I'm stubmbled on how to do that, and I would appreciate any help you can provide ;)
EDIT: I found this tutorial http://vhdlguru.blogspot.com/2010/03/entity-instantiation-easy-way-of-port.html
It's rather useful, but I'm interested, if I have entities ab, ac, ad and one top entity in which I want to instate those entities.
If I want to map ports of entity ab to ad entity ports, how should the code look like:
HA1 : entity work.ad port map(
    out2 => InstCacheIn1,
    out2 => InstCacheIn2,
    sum => s1,
    carry => c1
How to explicitly tell that out1, out2 are ports of entity ab, and I want to map them to ports InstCacheIn1 and InstCacheIn2 of entity ad?
Yes of course you can. Call it top.vhd and instantiate all 3 entities into it. Then use top.vhd with your testbench for simulation.
  • \$\begingroup\$ Thanks for the tip, that did the trick. However, can you check the edited part of my question? \$\endgroup\$
    – idjuradj
    Jul 26, 2015 at 23:02
