14
What are these circuit symbols (circled in red) in these diagrams?
Circuit Diagrams
I am studying high school introductory physics, and this image is from a problem on circuitry in my online course. The problem is unrelated to the meaning of these particular symbols, but I am curious and would like to know.
  • \$\begingroup\$ Symbol with +/- is a "rotating machine" with commutator or (seems less likely) slip rings. \$\endgroup\$
    – Russell McMahon
    Commented Jul 27, 2015 at 11:27
4 Answers 4
14
The bottom symbol in B is a fairly common symbol for a motor.
The other one seems to be an uncommon symbol for a generator. This page identifies it as a DC generator:
http://avstop.com/ac/apgeneral/basiccircuit.html
But this page says it's "AC power":
http://www.electronic-symbols.com/electric-electronic-symbols/electric-generator-symbols.htm
Both pages are missing the + and - signs. The presence of + and - signs and the overall context suggest it's meant as a DC generator, or (less likely) a generic voltage source.
Unfortunately, as my links show, there's not a lot of consistency in these kinds of symbols.
  • \$\begingroup\$ The "AC power" (not "AC generator") symbol in your second link is missing the +/- annotations included in the OP's diagrams. Of course, so is the one in the first link, but it references it with a annotated DC generator. \$\endgroup\$
    – Samuel
    Commented Jul 27, 2015 at 20:54
  • \$\begingroup\$ Thanks for the links to different sources. I'm learning that circuit symbols are rarely consistent! \$\endgroup\$
    – Eudokia
    Commented Jul 31, 2015 at 3:47
DC generator (x 4) and DC motor (x 1).
Adam Hauns answer is mostly right, but both references say dc generator, ac generators does not have +-, while dc does.
It appears that the circuits are given as possible answers to a problem. If this is the case, (A) is not a valid answer. If (B) is correct, you have a DC generator and a DC motor connected in series. If (C) is correct, you have a DC generator acting like a DC motor because it is connected to a battery. If (D) is correct, you have a DC generator connected to a lamp, and its current is being measured.
  • \$\begingroup\$ ??? (A) Generated power heats resistor, (B) Generator drives motor, (C) Generator charges battery, and (D) as stated above. They all work for me :) \$\endgroup\$
    – EBlake
    Commented Jul 30, 2015 at 22:31
