I was good at this but unfortunately I have forgot almost everything... So the question is what are the steps to tell if a transform function is for IIR or FIR filter:
$$H(z) = \frac{z^3+5z^2+3z+1}{10z^3}$$
Also how to tell it it has linear phase response?
  • \$\begingroup\$ For the first part of your question an FIR filter only looks at previous inputs while an IIR filter also looks at previous output results. \$\endgroup\$ Jul 27, 2015 at 10:02
    \$\begingroup\$ I'm voting to close this question as off-topic because it belongs on DSP.SE \$\endgroup\$
    – endolith
    Jul 27, 2015 at 13:45
    \$\begingroup\$ @endolith Standard SE policy is NOT to migrate to Beta sites. As is this EE.SE's policy. It is on topic to both stacks, and as such, should stay here. \$\endgroup\$
    – Passerby
    Aug 6, 2015 at 4:28
  • \$\begingroup\$ @Passerby I don't agree with that. Having something on-topic on 2 different sites leads to duplicate questions and dilutes the quality of both sites. This is 100% a DSP question and belongs on DSP.SE. meta.electronics.stackexchange.com/a/129/142 \$\endgroup\$
    – endolith
    Aug 6, 2015 at 6:20
    \$\begingroup\$ @endolith meta.stackexchange.com/questions/178444/… DSP.SE is a beta site and questions should 100% not be migrated to beta sites. Also meta.electronics.stackexchange.com/questions/3384 mainly, We only migrate questions because they are off-topic on this site. It is perfectly possible for a question to be on-topic on multiple sites, but that is not a reason to migrate it elsewhere. The OP asked their question here, so if it's on-topic here, then it should stay here. \$\endgroup\$
    – Passerby
    Aug 6, 2015 at 6:25
First, note that FIR/IIR is not the same as non-recurrent/recurrent (where recurrent means that the output depends on previous inputs and previous outputs).
You can have a non-recurrent filter with infinite impulse response (e.g. \$h[n] = sinc(n/3)\$, which cannot be expressed as a recursion). And you can have a recursive construction for a FIR filter.
But, for finite-order systems, you can in general associate FIR with non-recursive forms, and IIR with recursive forms.
Your transfer function has a trivial denominator, so there is no recurrence. Divide by \$z^3\$ and you get:
$$H(z) = 0.1 + 0.5 z^{-1} + 0.3 z^{-2} + 0.1 z^{-3}$$
Trasnform back and you get the impulse response:
$$h[n] = 0.1 \delta[n] + 0.5 \delta[n-1] + 0.3 \delta[n-2] + 0.1 \delta[n-3]$$
The impulse response starts at \$n=0\$ and ends at \$n=3\$, therefore its support is finite (FIR).
If you had poles not at \$z=0\$, then you have an IIR filter. For example, if the denominator is \$\frac{\cdots}{z^2 (z-1/3)}\$, now you have a pole at \$z=1/3\$, and your recurrence equation yields (divide top and bottom by \$z^3\$ first):
$$Y(z)(1-1/3 z^{-1}) = X(z)(0.1 + 0.5 z^{-1} + 0.3 z^{-2} + 0.1 z^{-3})$$
$$y[n] - 1/3 y[n-1] = 0.1 x[n] + 0.5 x[n-1] + 0.3 x[n-2] + 0.1 x[n-3]$$
So you can see that the output \$y[n]\$ depends on previous inputs and also on the previous output \$y[n-1]\$.
Now to phase linearity:
Causal, finite-order digital filters can only be of generalized linear phase if the impulse response is symmetric (check these slides for the 4 types of symmetry; wikipedia article is undergoing copyright discussions).
So, for your original filter, the impulse response terms are { 0.1 0.5 0.3 0.1 }; not symmetric, so not linear phase.
IIR causal filters will never be linear phase (impulse response starts at 0 and never ends, so no symmetry possible).
