I have a text file named "Hex_data.txt". I want to load content of Hex_data.txt into a variable name RAM in verilog. When I try this, I get an error that the text file can't be found. Where is this file loaded from?
The content of "hex_data.txt" :
21
a4
2a
26
7a
ff
6f
I want to create a variable name "RAM" defined like:
reg [6:0] RAM; in which the above content save like:
RAM[0]=21
RAM[1]=a4
RAM[2]=2a
RAM[3]=26
RAM[4]=7a
RAM[5]=ff
RAM[6]=6f
I wrote a code:
module file_read;
  reg [7:0] RAM [0:6];
  initial $readmemh("Hex_data.txt", RAM);
  integer i;
  initial begin
    $display("data:");
    for (i=0; i < 7; i=i+1)
      $display("%d:%h",i,RAM[i]);
  end
endmodule
But the above code not working. How can i get desired output?
  • \$\begingroup\$ You could use excel. Load the file, add another column counting 0,1,2... another row with: ="RAM["&A2&"]="&A1 Then copy-paste that block into the design file. You could use bash todo a similar thing, or python,perl... OR do you want to wrap it all in verilog? \$\endgroup\$ – JonRB Jul 27 '15 at 12:25
  • \$\begingroup\$ verilog.renerta.com/mobile/source/vrg00016.htm Watch here \$\endgroup\$ – Junior Jul 27 '15 at 12:57
Xilinx presented this use case in the Synthesis User Guide for Vivado UG901 on page 126. This example also works for the Xilinx ISE tool chain, but I don't know the User Guide number.
The essential part of code is this:
reg [31:0] ram [0:63];
initial begin
  $readmemh("rams_init_file.data", ram);
end
There are two read functions:
- $readmemb -> binary
- $readmemh -> hexadecimal
module file_read;
initial
$readmemh("hex_data.txt", RAM);integer i;
initial begin for(i=0;i<7;i=i+1)
$display ("RAM[%d]=%h",i,RAM[i]); end  endmodule
