9
This piece of metal was packaged with my new soldering iron.
Mysterious piece of metal
Does anybody know what is it ? Is it a stand ?
14
Yes it is a stand, if you push out the center piece so that it is about 45 degrees or more from the rest of the metal then you have a stand which will hold the iron off the surface. This tends to come with the Maplin irons in the UK.
  • \$\begingroup\$ Thanks ! I was not sure it was a stand: I fear that it will become too hot for my table when holding the iron. As for the iron itself, it is branded "Antex", but it seems that Maplin/Antex sells the same products anyway. \$\endgroup\$
    – JonathanD
    Mar 10, 2010 at 21:02
    \$\begingroup\$ If you prop the plastic part on the soldering iron handle on the stand then it will not get hot. \$\endgroup\$
    – JohnC
    Mar 10, 2010 at 22:08
    \$\begingroup\$ As the iron will be resting on the edge of the metal stand, there will not be enough surface area to conduct the heat from the iron to cause a scorch mark on the table top. Personally, I found that the sand to be too light but it's a freebie really. \$\endgroup\$
    – geo_melb
    Mar 22, 2010 at 1:08
    \$\begingroup\$ @JonathanD - Also, if it is steel, the thermal conductivity is quite low. It will not get significantly hot anywhere but the small area near where the iron touches. \$\endgroup\$ Sep 12, 2011 at 8:22
    \$\begingroup\$ Bin it and get a proper one, like this: uk.farnell.com/antex/st-4/stand-for-antex-soldering-iron/dp/… - you'll appreciate it later! \$\endgroup\$
    – Al Bennett
    Sep 12, 2011 at 11:19
Yup, it's a stand - here's a photo of it assembled:
The holes are for securing it to the bench with a couple of screws.
  • 7
    \$\begingroup\$ I think the holes are just strain relief but as you say they can be used to fasten the stand to a bench. \$\endgroup\$
    – JohnC
    Mar 10, 2010 at 22:10
