I have a gsm module but unfortunately it doesnt have an output for mic and speakers. I need to integrate mic and speaker too. In my GSM module, there are male pins available for mic_P
mic_N
for microphone and spk_P
spk_N
but I dont know how to connect these to speakers and microphone. Does anyone have any idea about this?
Please share.
\$\begingroup\$ Quite often you can just connect MIC_P to the positive side of an electret microphone and MIC_N to the negative. Likewise with a small speaker or set of headphones. The module won't drive a large speaker. Check if there is a voltage across MIC_P and MIC_N. \$\endgroup\$– pjc50Jul 28, 2015 at 17:44
\$\begingroup\$ @pjc50 electret microphone... is it the normal microphone or something else? \$\endgroup\$– anna carolinaJul 28, 2015 at 17:46
\$\begingroup\$ It's .. an electret microphone. It should be in the description in a parts catalog. \$\endgroup\$– pjc50Jul 28, 2015 at 17:49
1 Answer
You can use electret microphone. Connect its positive to MICP
& negative to MIC_N
For speakers, I have used this type of speakers. Connections are same.
Alternatively, for testing purpose you can also use your headphone. Cut the headphone wire and you will find wires to connect with SPK_P
SPK_N
MIC_p
MIC_N
