I'm debugging an embedded system and get intermittent binary loading errors when flashing the binary through gdb (well, arm-none-eabi-gdb, the toolchain gdb client). Here are the details of my setup:
- LPC1768 dev board at firmware rev 141212 (Cortex-M3 processor with CMSIS-DAP debugger interface)
- GCC-ARM Toolchain (including arm-none-eabi-gdb client debugger)
- Target hardware connected via USB serial (nothing special done to connect it, Ubuntu 14.04 just auto-mounted it as a USB storage device)
- pyOCD 0.4.5
- pyusb 1.0.0rcl
- Ubuntu 14.04 as a VirtualBox 5.0.0 guest OS (Win7 host OS).
The GDB server launches on the target (remote) hardware well enough:
${ubuntu:honkaboy} python gdb_test.py
INFO:root:new board id detected: 10100936d079f041404682e3fb480a743a63
INFO:root:board allows 10 concurrent packets
INFO:root:DAP SWD MODE initialised
INFO:root:IDCODE: 0x2BA01477
INFO:root:6 hardware breakpoints, 4 literal comparators
INFO:root:CPU core is Cortex-M3
INFO:root:4 hardware watchpoints
INFO:root:GDB server started at port:3333
INFO:root:One client connected!
And the gdb client launches fine too:
{ubuntu:honkaboy}: /usr/local/gcc-arm-none-eabi-4_9-2015q2/bin/arm-none-eabi-gdb Motion-Control.59.elf
GNU gdb (GNU Tools for ARM Embedded Processors) 7.8.0.20150604-cvs
[bunch of omitted startup messages (canned and irrelevant)]
Reading symbols from Motion-Control.59.elf...done.
(gdb) target remote localhost:3333
Remote debugging using localhost:3333
0x00003cb0 in Reset_Handler ()
But when I load the binary through the client, I often will get a data transfer timeout:
Client terminal:
(gdb) load
Loading section .text, size 0x11940 lma 0x0
Loading section .ARM.exidx, size 0x8 lma 0x11940
Loading section .data, size 0x134 lma 0x11948
Remote connection closed
Server terminal:
[======= ] 35%Exception in thread Thread-2:
Traceback (most recent call last):
File "/usr/lib/python2.7/threading.py", line 810, in __bootstrap_inner
self.run()
File "/usr/local/lib/python2.7/dist-packages/pyOCD/gdbserver/gdbserver.py", line 318, in run
resp, detach = self.handleMsg(packet)
File "/usr/local/lib/python2.7/dist-packages/pyOCD/gdbserver/gdbserver.py", line 390, in handleMsg
return self.flashOp(msg[2:]), 0
File "/usr/local/lib/python2.7/dist-packages/pyOCD/gdbserver/gdbserver.py", line 548, in flashOp
self.flashBuilder.program(chip_erase = self.chip_erase, progress_cb=progress_cb, fast_verify=self.fast_program)
File "/usr/local/lib/python2.7/dist-packages/pyOCD/flash/flash_builder.py", line 250, in program
flash_operation = self._page_erase_program(progress_cb)
File "/usr/local/lib/python2.7/dist-packages/pyOCD/flash/flash_builder.py", line 486, in _page_erase_program
data = self.flash.target.readBlockMemoryUnaligned8(page.addr, len(page.data))
File "/usr/local/lib/python2.7/dist-packages/pyOCD/target/cortex_m.py", line 569, in readBlockMemoryUnaligned8
mem = self.readBlockMemoryAligned32(addr, size/4)
File "/usr/local/lib/python2.7/dist-packages/pyOCD/target/cortex_m.py", line 667, in readBlockMemoryAligned32
resp += self.transport.readBlock32(addr, n/4)
File "/usr/local/lib/python2.7/dist-packages/pyOCD/transport/cmsis_dap.py", line 221, in readBlock32
resp = self._transferBlock(size, READ | AP_ACC | AP_REG['DRW'])
File "/usr/local/lib/python2.7/dist-packages/pyOCD/transport/cmsis_dap.py", line 402, in _transferBlock
return self.protocol.transferBlock(count, request, data)
File "/usr/local/lib/python2.7/dist-packages/pyOCD/transport/cmsis_dap_core.py", line 256, in transferBlock
self.interface.write(cmd)
File "/usr/local/lib/python2.7/dist-packages/pyOCD/interface/pyusb_backend.py", line 155, in write
self.ep_out.write(data)
File "/usr/local/lib/python2.7/dist-packages/usb/core.py", line 360, in write
return self.device.write(self, data, timeout)
File "/usr/local/lib/python2.7/dist-packages/usb/core.py", line 921, in write
self.__get_timeout(timeout)
File "/usr/local/lib/python2.7/dist-packages/usb/backend/libusb1.py", line 834, in intr_write
timeout)
File "/usr/local/lib/python2.7/dist-packages/usb/backend/libusb1.py", line 912, in __write
_check(retval)
File "/usr/local/lib/python2.7/dist-packages/usb/backend/libusb1.py", line 592, in _check
raise USBError(_strerror(ret), ret, _libusb_errno[ret])
USBError: [Errno 110] Operation timed out
Exception in thread gdb-packet-thread (most likely raised during interpreter shutdown):
File "/usr/local/lib/python2.7/dist-packages/pyOCD/gdbserver/gdbserver.py", line 119, in run
<type 'exceptions.AttributeError'>: 'NoneType' object has no attribute 'error'
As I mentioned, the error is intermittent. It happens probably 70% of the time, the other 30% it loads all the way just fine and I'm able to debug the program normally. The load percentage at which the timeout occurred in my example here was 35%, but that's not consistent. Sometimes it times out at 10% loaded, sometimes 69%, etc.
