I am interfacing with GSM SIM900. I wrote a program so that I can read the SMS in SIM900. I have made a function to transmit and receive. Whenever msg comes, GSM responds with +CMT along with slot number.I am trying to extract that slot number which is in digits, but I am getting garbage values
Here is the code:
while(1)
    if (serial_Rx() != NULL) // SOMETHING PRESENT TO BE READ
        serial_Tx("done"); // print done
        PORTC = 0x01; // turn on led
        for (int i=0;i<=14;i++)
            data[i] = serial_Rx(); //storing received in data
            if(isdigit(data[i]))
                serial_Tx("enter");
                PORTC = 0x02;
                data1[i] = data[i];
                serial_Tx(data1[i]);
Transmit and receive funstions:
void serial_Tx(char *str)
    for (unsigned int i=0;str[i]!=0;i++)
        UDR=str[i];
        while(!(UCSRA&(1<<UDRE)));
char serial_Rx()
    //Wait untill a data is available
    while(!(UCSRA & (1<<RXC)))
         //Do nothing
    //Now USART has got data from host and is available is buffer
    return UDR;
void uart_put(char data)
    UDR=data;
Hyperterminal:
  • \$\begingroup\$ If I remeber correctly your serial_TX functions expects a string (char*) as param but I suppose k is a single char variable, try with the uart_put function. You should have got a warning about this when you have built the code. \$\endgroup\$ Commented Jul 29, 2015 at 8:30
  • \$\begingroup\$ @BenceKaulics Hey I have made few changes in the code. I have removed the second for loop and included the isdigit function in first loop. I am getting enter on output that means control is entering my isdigit function and has found that digit but serial_Tx(data1[i]) is not running. Can you tell me whats wrong in this.? \$\endgroup\$ Commented Jul 29, 2015 at 12:17
  • \$\begingroup\$ You get the "enter" but nothing else? \$\endgroup\$ Commented Jul 29, 2015 at 12:32
  • \$\begingroup\$ @BenceKaulics yeah and even i checked it further by putting it in a if condition like if (data[i] >=5) {serial_Tx("match");else (serial_Tx("NO MATCH"), so I was getting match on output. I used >=5 because I didnt know the exact number and I assumed it to be greater than 5 because i know it may be 7 or 8 \$\endgroup\$ Commented Jul 29, 2015 at 12:40
  • \$\begingroup\$ Okey so you should definetly read about Strings, chars, and char array, char pointers in C. Serial_TX is for sending a string like "enter" or "match" but k and data[i] is a single char like 'a', 'b', 'c'. Try with uart_put(data[i]). \$\endgroup\$ Commented Jul 29, 2015 at 13:00
In your code the following function call is wrong:
Because data1[i] has a type of char but void serial_Tx(char *str) expects a char*, this function is for sending strings, not single characters. This way it causes runtime error, hence you won't get the expected output.
Though, it won't generate a compilation error, but the compiler will give a warning like this:
It is recommended to check and fix these warnings, because as you could see they could cause troubles in runtime.
So, replace the function above with the void uart_put(char data) function, like:
uart_put(data[i]);
and it will work.
  • \$\begingroup\$ it keep on showing the same value untill I press the reset switch. After reset, it shows new updated value, is it because the data in data1 is not getting cleared? \$\endgroup\$ Commented Jul 30, 2015 at 4:17
