Hi all I am interfacing with GSM SIM900 with atmega32. I am trying to extract the message contents. User will send message like CHANGE7532167845 to SIM installed in GSM device. So to extract this I am using for loop followed by many if conditions. All I need to do is to save the number in a another variable. Following is my code:
for(int k =0; smscontent[k]!=NULL;k++)
            if (smscontent[k] == 'C')
                if (smscontent[k+1] == 'H')
                    if (smscontent[k+2] == 'A')
                        if (smscontent[k+3] == 'N')
                            if (smscontent[k+4] == 'G')
                                if (smscontent[k+5] == 'E')
                                    if(isdigit(smscontent[k+6]))
                                        serial_Tx("MATCH");
My control is reaching isdigit because on terminal I am getting MATCH but after that what I should do to save number in a variable.? Please help
serial_Tx function
void serial_Tx(char *str)
    for (unsigned int i=0;str[i]!=0;i++)
        UDR=str[i];
        while(!(UCSRA&(1<<UDRE)));
You should check out some basic string handling tutorials.
I would suggest using strstr (C) or string::find (C++) instead of an elaborate if-if-if.
//C++
std::size_t found = smscontent.find("CHANGE");
if (found!=std::string::npos){
   std::string valueString = smscontent.substr(found+6/*strlen("CHANGE")*/);
   int value = std::stoi(valueString,nullptr);
I actually have no idea if the code above compiles or is anything like you're searching for.
//C
char buffer[20] = {'\0'};
int value = 0;
char * pposition = strstr(smscontent,"CHANGE");
ptrdiff_t position = pposition - smscontent;
if(pposition != NULL){
   strcpy(buffer, pposition);
   value = atoi(buffer);
There might be way easier options though, especially when using C++ or sscanf (if possible)
simply:
sscanf(smscontent,"CHANGE%u",value);
and the value will be saved in the variable: "value"
| improve this answer | |
  • \$\begingroup\$ ok so you mean to say by using strstr we can search for CHANGE and then using pointer, we will copy it in buffer, is it? \$\endgroup\$ – anna carolina Jul 30 '15 at 12:47
  • \$\begingroup\$ error: unknown type ptrdiff_t, do we need to include any header file for it? I think cstddef.h need to be included and this is for C++ I am in C \$\endgroup\$ – anna carolina Jul 30 '15 at 12:49
  • \$\begingroup\$ it's in stdio.h for me, but it's typedef int ptrdiff_t; so you could get away with a regular int I guess. \$\endgroup\$ – Paul Jul 30 '15 at 13:48
  • \$\begingroup\$ hey I have extracted the number and saved it in newnum which is a char. Now I am doing sprintf(call,"ATD%s;\r\n",newnum); and then serial_Tx(call); where serial_Tx is a function which transmit data serially but I am not getting any call. \$\endgroup\$ – anna carolina Jul 31 '15 at 4:59
  • \$\begingroup\$ %s would specify a string (char array)? And newnum was a char. Also, an (unsigned) char can only hold up values from 0 to 255. And be sure to send the serial string to the SIM900 modem and not just to your terminal/debug/screen \$\endgroup\$ – Paul Jul 31 '15 at 6:14
