I am asked to build a 5 V /24 V circuit interface using an ATMEGA328P.For that i built a little comparator circuit to get a 5 volt level on a I/O pin .
My problem is that the output of the comparator can be high while the I/O pin can be configured as a 5 volt output . I thought a little then decided to add a 4.8 zener diode as below.[Edited]
Is this circuit safe to use? enter image description here
  • \$\begingroup\$ Your diodes will block all current, so it won't work. What do you mean "the sensor using this circuit can be high while the pin is also high"? \$\endgroup\$ Jul 30 '15 at 16:19
  • \$\begingroup\$ Why is the pin configured as output? Why are you using a comparator; does the sensor output an analog signal? \$\endgroup\$
    – CL.
    Jul 30 '15 at 17:11
R1 connected in series with the supply is not a good idea. The comparators can draw as much as 2mA (0.8mA typical) and you have zero common mode range to spare.
R8 also seems pointless- you will get only 2.5V signal from the comparator.
You can leave R2 in place, increase to 20K and replace D1 with a resistor as Kevin suggests (maybe 2K).
  • \$\begingroup\$ If the Pins is configured as output and is outputing a low level does the 5 volt from the comparator sound risky for it? \$\endgroup\$ Jul 30 '15 at 19:23
  • \$\begingroup\$ No, it is just 5V thorough the pullup resistor from the comparator plus the series resistor.. so 22K in my example, and only 230uA. The comparator output is open-collector so it can only pull down. \$\endgroup\$ Jul 30 '15 at 19:46
Since the comparator is an open collector output there is no problem if the output is high while connected to the MCU whose output is driving high. There is a problem if the comparator is driving low and the MCU is driving high as there will be a conflict and a large current could flow.
I would remove r8 and replace D1 with a 10K resistor (value very non-critical could be 470 ohm - 22K).
Now if the comparator output and the MCU pin are in conflict the current will be limited to a safe level.
  • \$\begingroup\$ When i did so ,i have no more a 5 volt output when the comparator is high and MCU low. \$\endgroup\$ Jul 30 '15 at 17:51
  • \$\begingroup\$ Doesn't the pin marked 1 on your schematic go the MCU? In that case I don't understand what you are attempting. Can you describe more fully. I thought you were interfacing a 24v signal into an MCU. \$\endgroup\$ Jul 30 '15 at 18:23
