I'm using an AVR Mega 168 to generate a sine wave via pulse width modulation. My goal is to generate a sine wave with a frequency of approximately 50 Hz. I understand that the PWM frequency needs to be as fast possible so its easier to attenuate in the filter.
So far, my µC is running at 8 MHz using the internal RC oscillator (I plan on moving to a crystal later on - taking this one step a time). This provides me with a maximum PWM base frequency of 8x106/256 (fast PWM mode) = 31.25 kHz.
My program updates the duty cycle whenever timer0 overflows i.e. every 32 µS (I think... since 1/31250 = 32 µS).
My question now is, how can I 'control' the frequency of the actual sine wave? I can easily slow down by prescaling but that would obviously make the base frequency quite low.
I have included my code below:
uint8_t i=0;
int main(void)
     int ipwm;
     DDRD = 0xFF;
     TCCR0A = 0b10000011;
     TCCR0B = (1 << WGM12);
     TIMSK0 |= (1 << TOIE0);
     TIFR1 |= (1 << OCF0A);
     TCCR0B = (1 << CS10);
     TCNT0 = 0;
     OCR0A = 128;
     sei();
     for(;;)
     return 1;
 ISR(TIMER0_OVF_vect)
    OCR0A=pgm_read_byte(&sinewave[i]); // update duty cycle
    i++;
The 31.25kHz is 625x your 50Hz. So all you have to do is build a 625 entries sine lookup table, and at each interrupt set your output compare value to the next table entry. If you have a 32\$\mu\$s interrupt you'll have ran over the full table (=full sine cycle) every 625 x 32\$\mu\$s = 20ms, so that will be your 50Hz.
  • \$\begingroup\$ Thank you! Just generated 625 values and the frequency is now 50Hz (I measured using my DMM). \$\endgroup\$
    – Saad
    Aug 16, 2011 at 16:28
