I would like to know if is it possible to build up a rule that treats a single net in different way.
I have some circuits in which some nets needs to be dimensioned for high current. So I create a net class and I assign to that net class the desired width. So far, so good.
The problem is that not all tracks of that net need to this width for high current (for example think about parallel components). So I would like to make a rule that makes the net bigger only where it needs.
Is it possible?
I've tried with some rules but without any result: I made the Net Class with all net for high current and then a Component Class with all and only the component connected to high current wire. I make this rule: InNetClass('HC') AND InComponentClass('HC')
... but obviously it doesn't work because the nets of class HC belongs also to component outside class HC.
How can I solve this?
