I have a simple circuit:
+12V -- R1 -- LED1 -- LED2 -- LED3 -- ground
If the Forward Voltage of an LED is 3V, and the Forward Current is 20mA, I can (I believe) calculate the required resistance of the resistor as (12V - (3 * 3V)) / 0.02A = 150Ω.
From what I understand, that should give me a Voltage Drop of 3V over the resistor and each LED respectively, and a current of 20mA through the circuit - perfect.
In the simulation of this circuit, I get a Voltage Drop of 4.01V, 2.66V, 2.66V, 2.66V respectively, and a current of 26.74mA through the circuit, which is too high for the LEDs.
This makes me think that I don't understand the relationship between Forward Voltage and Voltage Drop, and therefore, how am I supposed to calculate a correct resistor value that won't burn out the LEDs?
Apologies if this is asked a lot or is really simple, but I've been searching for ages and haven't come up with anything.
