I am working on an android accessory development. Currently whenever I plugin my Android device to the PIC24F (which I had programmed in the PIC24F) but I haven't installed in the Android phone
It display: "Accessory Development Starter Kit (PIC24F) for Android(tm)
No installation applications work with this USB accessory. Learn more about this accessory at the microchip"
I tried using MPLAB to read/access and find the sentence but there isn't any result.
How can I modify the sentence?
The software I am using:
MPLAB IDE Version 8.73 MPLAB C Compiler for PIC24 and dsPIC v3.30
The device/tools I am using:
DM240415 - PIC24F Accessory Development Starter Kit for Android
  • \$\begingroup\$ Are you using your own code or some example code? \$\endgroup\$
    – Kellenjb
    Aug 19, 2011 at 13:53
16-bit PIC24 and dsPIC devices don't have any EEPROM! They only have flash memory, but EEPROM can be emulated:
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1824&appnote=en530593
  • \$\begingroup\$ So it isn't the EEPROM that store the message. If I want to edit the message, is it possible? \$\endgroup\$
    – Ezylryb
    Aug 20, 2011 at 6:46
  • \$\begingroup\$ You are right, PIC24F doesn't have a EEPROM! :) \$\endgroup\$
    – Ezylryb
    Aug 22, 2011 at 14:56
I have found the way to change the default message!
Let say the default displays this: "Accessory Development Starter Kit (PIC24F) for Android(tm)
It seem that when programming to the PIC24F in MPLAB, we have to declare the manufacturer, version, uri, description, etc. The Android device will then automatically get the value when the accessory are attached. Unfortunately, we can't change the body part of the message.
Sample Example of the Output
E.g. My description is "Hello World" and my uri is "www.helloworld.com".
It will display:
"Hello World
No installation applications work with this USB accessory. Learn more about this accessory at the www.helloworld.com"
