7
I am using a MOSFET to control the average voltage to a device by varying the duty cycle to the base as shown in the diagram below. My question is what is the best circuit to use in the "filter box" in order to "smooth" the PWM into its analogue equivalent. I have been told i can use a choke for this purpose, however is this the best approach.
Please note I want to smooth the PWM as the load is a peltier device and hence should not be driven by PWM. Further more there will be about 8A of current drawn by the peltier.
  • \$\begingroup\$ Have you looked at switching regulator circuits yet? \$\endgroup\$ Aug 10, 2015 at 4:34
    \$\begingroup\$ Just curious, why do you think a peltier needs a smooth current? \$\endgroup\$
    – bigjosh
    Aug 10, 2015 at 4:42
    \$\begingroup\$ I would like to smooth the PWM voltage as a peltiers sould not be constantly switched on and off. I have not looked into voltage regulator circuits yet. \$\endgroup\$ Aug 10, 2015 at 5:07
  • \$\begingroup\$ Mosfets do not have "base". It is called gate. \$\endgroup\$
    – ilkhd
    Aug 10, 2015 at 5:25
    \$\begingroup\$ Here's the reason for filtering the output: electronics.stackexchange.com/a/28637/8627 \$\endgroup\$
    – gbarry
    Aug 10, 2015 at 6:18
9
Add a Schottky diode, an inductor, and a capacitor, to create a buck-mode step-down voltage convertor like this:-
The inductor and capacitor create a smooth DC output voltage proportional to the PWM ratio. The diode recirculates current through the inductor when the FET is turned off. This is required to properly smooth the output voltage, and also prevents the inductor from producing voltage spikes that would kill the FET.
    \$\begingroup\$ Also note that the gate drive on M1 will need some care at 20kHz and 8A. \$\endgroup\$
    – Jon
    Aug 10, 2015 at 8:25
    \$\begingroup\$ What exactly do you mean by "care"? \$\endgroup\$ Nov 17, 2015 at 14:18
    \$\begingroup\$ When I try the circuit I fail to get a smooth volt over the load. \$\endgroup\$ Dec 21, 2015 at 15:21
    \$\begingroup\$ Higher inductance is OK, so long as it can handle the current. Higher capacitance is also OK. I used the minimum acceptable values for 20KHz PWM. With larger values you could use a correspondingly lower frequency. \$\endgroup\$ May 2, 2016 at 20:41
    \$\begingroup\$ @MikeGleasonjrCouturier - The inductor smooths current flow by producing an opposing voltage proportional to current change. Without the inductor before it the capacitor would rapidly charge to full supply voltage when the FET is turned on (current limited only by the FET's tiny Drain-Source resistance), then slowly discharge through the load when the FET is off. This makes the PWM ineffective, and the high current pulses stress the FET and create EMI - worse than not having any filter at all! \$\endgroup\$ Mar 16, 2019 at 22:43
7
The normal method to do what you want is to use either a series inductor or a LC filter: series inductor with capacitor across the load.
I spent much time many years ago playing with PWM control of Peltier cells. What we found way back then is that the Peltier efficiency went WAY up when we filtered the raw PWM into a nice, smooth DC supply instead of chopped DC.
