I'm planning to use a TL084 JFET quad op-amp with each op-amp configured as a voltage follower (datasheet). Some questions:
- Does Vcc+ have to equal -Vcc-? i.e. can I set them to Vcc+=15V, Vcc-=-8V?
- I'm planning to run the op-amp in a non-inverting follower configuration with the input V+ between -4V and 12V. The input common-mode voltage range says -12,15 V. Does this mean I can output any voltage between -4V and 12V in this configuration?
- The output short-circuit current is listed at 60 mA. Can I safely assume that my voltage follower can source ~60 mA of current?
- Should I be adding any passive components to this circuit to make sure it is stable?
