I am using MCP662 op-amp as differential amplifier:
First inputs' signal can vary from 0V to 3V and the second input signal can vary from 1V to 1.4V. MCP662 has common mode voltage range equal 1.7V (Vdd-1.3V). In this circuit Vin+ can exceed 1.7V (for example it is 2V when one input signal is 3V and another is 0). However, common mode voltage (Vin+ + Vin-)/2 will never exceed 1.7V.
Is the Vcm range be violated in this circuit? Can this circuit to be used when both input signals can vary between 0V and 3V?
Vcm
will never exceed the maximum value, why would it violate it? \$\endgroup\$ – Eugene Sh. Aug 10 '15 at 21:07
