Given a current transformer like this:
typical current transformer
there is an insertion resistance that appears as a very small equivalent series resistance on the measured circuit. Since it is usually small (say, 0.0001 \$\Omega\$), it can be neglected.
If you were to feed the current-carrying wire you are trying to monitor through the transformer multiple times to amplify your signal, does this also multiply the insertion resistance by the same amount? If I loop the wire through 10 times, does this multiply the insertion resistance by a factor of 10?
To clarify what I am asking, here is a link describing what insertion resistance means in the context of the type of transformer shown above.
  • \$\begingroup\$ Reflected impedance in a transformer goes as the square of the number of turns. \$\endgroup\$
    – John D
    Commented Aug 10, 2015 at 23:07
As JohnD hinted, the impedance ratio of a transformer is equal to the square of the turns ratio.
So if you have a 1000:1 transformer with a burden resistance of 100 ohms, the "reflected" resistance on the primary will be
$$\frac{100 \Omega}{1000^2} = 0.1 m\Omega$$
If you change the turns ratio to 1000:10 (= 100:1), but keep the burden resistance the same, the reflected impedance becomes:
$$\frac{100 \Omega}{100^2} = 10 m\Omega$$
... which is 100× as large, not 10×.
  • \$\begingroup\$ Interesting, but for most current transformers, like the one above, the # of turns is not given. At most, the output voltage for a given input current is. Is that sufficient for calculating the effective insertion resistance? \$\endgroup\$
    – iwantmyphd
    Commented Aug 11, 2015 at 0:54
  • \$\begingroup\$ I think you're confusing two current-measuring technologies. Current-sensing resistors are usually specified in terms of voltage drop for a given maximum current, which is really just another way of specifying their resistance. Current-sensing transformers are always specified in terms of their turns ratios, along with their maximum current rating. \$\endgroup\$
    – Dave Tweed
    Commented Aug 11, 2015 at 1:03
    \$\begingroup\$ ... but in any case, in terms of your specific question, the exact number of turns on the secondary doesn't matter -- regardless of what it is, if you have 10x the turns in the primary and keep everything else the same, the primary impedance will go up by 100x. \$\endgroup\$
    – Dave Tweed
    Commented Aug 11, 2015 at 1:08
  • \$\begingroup\$ thanks, I'm just going off of the mfg's website. They refer to insertion resistance when using their current transformer. Here's the link: pearsonelectronics.com/insertion-resistance \$\endgroup\$
    – iwantmyphd
    Commented Aug 11, 2015 at 1:48
  • \$\begingroup\$ What about the DCR of the secondary and the burden resistance .this also gets reflected \$\endgroup\$
    – Autistic
    Commented Oct 22, 2015 at 2:31
