So I was looking at the graph of the white LED, intensity vs wavelength and I observed two peaks. enter image description here
Which peak would I choose in the formula Eg = 1240 / lambda?
  • 4
    \$\begingroup\$ I suspect the phosphorescence has nothing to do with the internal working of the LED - it's possibly a coating that is activated by the blue light from the LED and in turn produces other colours to give an illusion of white. I could be totally wrong of course. \$\endgroup\$ – Andy aka Aug 11 '15 at 14:41
Quote from here, a pdf article on the subject: -
This means you use the blue luminescence wave length for your calculation.
| improve this answer | |
