Transformer pulled from EL wire inverter enter image description here Hi, I pulled this transformer from an EL wire inverter and am trying to figure out how to infer:
  • Which pins correspond to the primary and secondary coils
  • The ratio of the windings
  • Any other useful information I can glean.
There are only two markings on the top, none on the bottom. The top markings appear to be "45" on one side and, catty-corner to that, an "H". the pins on the bottom are symmetrically aligned, not offset like some transformers I've seen. I checked the resistance between pins and found:
  • Green-to-green: 70 ohms
  • White-to-white: 0.4 ohms
  • Green-to-white (side marked "45"): 1.0 ohms
  • Green-to-white (side marked "H): 68.6 ohms
...for background, I'm trying to implement the circuits described in Disney Research's "Tesla Touch" and "Revel" works (I can't add links because I don't have enough points). The papers call for a flyback transformer that boosts 3-5v to about 300v, which is significantly less than the voltages needed by other plasma- and arcing-related flyback projects I've seen online.
My understanding was that EL wire takes about 600v at similarly small currents, which is why I pulled the transformer from an EL wire inverter. However, I'm having trouble getting reliable performance from the transformer and am hoping with this question to resolve some fundamental questions I have about the component.
Thanks in advance for any help you can provide!
AKA
  • \$\begingroup\$ What test equipment do you have? \$\endgroup\$ Aug 11, 2015 at 20:23
  • \$\begingroup\$ Multimeter and oscilloscope but no function generator (tho I also have teensy 3.1, which has pretty adjustable PWM) \$\endgroup\$
    – AKA
    Aug 11, 2015 at 21:43
  • \$\begingroup\$ 70 ohm is HV, 1 ohm is low voltage, 0.4 ohm is useful if you want to make a resonant converter. Or you can ignore it and drive the 1 ohm with a MOSFET using teensy as gate drive. If you decide to make a resonant converter figure out the phasing of 1 ohm and 0.4 ohm. \$\endgroup\$ Aug 11, 2015 at 22:31
  • \$\begingroup\$ Refer to Linear Tech app.note 118 for ideas. \$\endgroup\$ Aug 11, 2015 at 22:37
  • \$\begingroup\$ I wouldn't call this reverse engineering since your aim is not to actually design or build a similar transfomer. You are just trying to infer some characteristics from measurements. \$\endgroup\$
    – realtime
    Aug 12, 2015 at 2:17
This transformer thing looks like basically a tapped inductor.
Perhaps you can determine the inductance and turns ratio by applying a pulse signal through a resistor and monitoring the rate of rise of current through the resistor. With a fixed voltage, the current (and thus the voltage across the series resistor) should rise linearly with time (ignoring the coil resistance and the voltage across the inductor- so only for small voltages wrt the pulse voltage). In other words, if you apply (say) 5V through a resistor and look at the slope of the voltage across the resistor while it is still close to 5V.. the rate of change will be dv/dt ~= V/L, so L ~= V/(dv/dt).
The turns ratio is the ratio of the square roots of the inductances, measured with the other coil open.
There are other things that are important in a flyback converter- especially the saturation current, but this should get you started. Probably the core is gapped (an air gap inserted in the magnetic circuit) to keep the core from saturating. It will be difficult to determine the number of turns non-destructively.
  • \$\begingroup\$ Thank you for your answer! I haven't "accepted" it because it seems most likely now that it is a 1:1 "audio" transformer - I ran a ~100kHz sine wave through it and observed no change in voltage levels on the other side... \$\endgroup\$
    – AKA
    Aug 19, 2015 at 21:11
