-1
I wasted a lipo battery earlier. I googled so I know that when it goes flat it is unusable. Then I bought another battery of same type 3s. After using it for a month or 2, it suddenly started showing voltage 8.5 which is supposed to be 11.1 volt. At charging the cell 1 and 2 are green, while cell 2 shows red light, means not charged. I am using it in my quad copter which is currently under making. What should I do? I opened the battery pack, the solder connections are fine. I checked separately the voltages of the 3 cells using multi meter cell 2 read 0 volt. Other one 4 volt. Any suggestion would be appreciated.enter image description here Imax b3 charger
closed as off-topic by Matt Young, Daniel Grillo, PeterJ, Ricardo, Dave Tweed Aug 13 '15 at 14:09
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions on the use of electronic devices are off-topic as this site is intended specifically for questions on electronics design." – Matt Young, Daniel Grillo, PeterJ, Ricardo, Dave Tweed
If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ Does your LiPo charger have cell equalization connections to the battery pack? It sounds as if the individual cells are not being charged properly. \$\endgroup\$ – Dwayne Reid Aug 12 '15 at 6:13
  • \$\begingroup\$ My charger have no buttons over it. Just female header for battery insertion, and lights. \$\endgroup\$ – Sulaiman Ayub Aug 12 '15 at 6:18
  • \$\begingroup\$ please, Post the image of your charger with the model number. \$\endgroup\$ – Arjun Aug 12 '15 at 7:30
  • \$\begingroup\$ I am trying. But is the problem with the charger, \$\endgroup\$ – Sulaiman Ayub Aug 12 '15 at 9:46
  • \$\begingroup\$ What capacity is your li-po battery? \$\endgroup\$ – Arjun Aug 12 '15 at 10:28
Lithium polymer batteries should be handled properly. Most important thing is, it should not be discharged below 3 volt per cell. This might completely damage the cell. You did not mention whether or not your charger worked for a single time. Did you conform the proper functioning of your charger? If you have another pair of 2s or 3s lithium battery, then conform your battery charger is fine to use. But I hardly doubt that. From the very begining your charger did not work properly, and you did continously use it for your flying machine. It may have happened that you don't have your low voltage cutoff set properly in the ESC which led deep discharge of your battery. It is not always necessary for lithium polymer battery to die because of deep discharge, but deep discharge might have caused damage to the Cell 2. My assumption is that you have a faulty li-po battery charger. And a Faulty cell because of the deep discharge.
Solution
  1. Check your battery charger
  2. Check your ESC setting (refer its manual, and properly calibrate your ESC)
Its just my assumption, Other may point out what actually had happened. :)
  • \$\begingroup\$ I think the reason was that my quadcopter has 4esc's which takes 30amp. And battery was of 10c 2200mah means 10x2200m 22amp discharge rate. And required is 30ampx4esc's 120amp rate. \$\endgroup\$ – Sulaiman Ayub Aug 12 '15 at 14:48
  • \$\begingroup\$ can you state the model number of your esc and its current rating? \$\endgroup\$ – Arjun Aug 12 '15 at 15:36
  • \$\begingroup\$ 30amp esc esc 30amp \$\endgroup\$ – Sulaiman Ayub Aug 12 '15 at 15:47
  • \$\begingroup\$ See this I hope it has the information you need. \$\endgroup\$ – Arjun Aug 12 '15 at 16:23
  • \$\begingroup\$ I have seen this already \$\endgroup\$ – Sulaiman Ayub Aug 12 '15 at 18:21
