-2
u8 i2c_read_register(u8 mem_address, u8 *data_read)
    u8 temp = 0;
    u8 ack = 0;
    u8 device_address = (IQS_ADDR << 1);
    u8 polling_attempt = 0;
    // send address
    ack = i2c_send_byte(device_address);
#ifdef POLLING
    while ((ack) && (polling_attempt < POLLING_ATTEMPTS))
        i2c_wait();
        i2c_wait();
        i2c_start();
        polling_attempt++;
#endif
    if (!ack)
        i2c_send_byte(mem_address);
        i2c_repeat_start();
        device_address = (IQS_ADDR << 1) | 0x01;
        temp = i2c_read_byte(1);
        (*data_read) = temp;
    return ack;
  • Notes In order to read two Byes I need to call the function Like This:
    i2c_read_register(DEBUGGING_EVENTS, &data_buffer[1], 2);
With (2) representing the Number of Bytes. But as the function stand it only takes two arguments not three.
  • 4
    \$\begingroup\$ Have you considered calling i2c_read_byte() twice? \$\endgroup\$ – user207421 Aug 12 '15 at 11:20
  • \$\begingroup\$ @EJP Yes, but its not working accordingly \$\endgroup\$ – mChad Aug 12 '15 at 11:22
  • \$\begingroup\$ The Memory Address that I'm trying to read always return two bytes, First byte for Events, and 2nd Bytes for movement, so I have to specify reading the two bytes in my function. \$\endgroup\$ – mChad Aug 12 '15 at 11:26
    \$\begingroup\$ As suggested - call i2c_read_byte() with the two different addresses you are trying to read from. If this doesn't work, it implies that the device is expecting a multi-byte read and the data is not valid if this is not the case (you should already have seen this in the datasheet). In this case, try Googling "i2c multi-byte read" and "i2c repeated start condition". This info is normally included as a simple timing diagram in the datasheet too. \$\endgroup\$ – stefandz Aug 12 '15 at 11:40
    \$\begingroup\$ OK - so this is really about STM8 multi-byte reads. I haven't worked with STM8 parts before, but a quick Google on this brought up ST application note AN3281. That looks worth a read - but the fact I found something that quickly suggests you have not done much research on this. \$\endgroup\$ – stefandz Aug 12 '15 at 12:07
In the software package for the stm8 Eval board is an example project which is using a serial eeprom which is able to read multiple bytes.
sEE example software
  • \$\begingroup\$ Yes I do I have the file, as you may have noticed I already Have a function that was working but only for reading a single byte. So I only wanted to modify it to read two Bytes instead of writing a whole new Function. \$\endgroup\$ – mChad Aug 13 '15 at 6:57
After Hours of Trying to modify the Code I finally managed to get the Specified two Bytes from my i2c_read_register() Function.
u8 i2c_read_register(u8 register_address, u8 *data_read, u8 NumbOfBytes)
    u8 i;
    u8 temp = 0;
    u8 ack = 0;
    // send address
#ifdef POLLING
        i2c_wait();
        i2c_wait();
        i2c_start();
        polling_attempt++;
#endif
    if (!ack)
        i2c_send_byte(register_address);
        i2c_repeat_start();
        //temp = i2c_read_byte(1);
        //(*data_read) = temp;
        if(NumbOfBytes > 1)
            for(i = 0; i < NumbOfBytes -1; i++)
            data_read[i] = i2c_read_byte(0);
        data_read[i] = i2c_read_byte(1);
    return ack;
All That was needed, was to add a for Loop Incrementing the Number of Bytes to read as input by user with the u8 NumbOfBytes variable.
And you call the function Like This:
i2c_start();
i2c_read_register(DEBUGGING_EVENTS, &data_buffer[0], 2);
i2c_stop();
events = data_buffer[0];    // Main Events  1st Byte
movement = data_buffer[1];  // Debugging Events 2nd Byte
  • \$\begingroup\$ You might want to flag your own answer as correct, so that others know that this is now solved. \$\endgroup\$ – stefandz Aug 12 '15 at 20:06
  • \$\begingroup\$ @ stefandz, Yes The u=rules says u have to wait for 48 Hours to Flag your own answer as solution. \$\endgroup\$ – mChad Aug 13 '15 at 6:48
