I have a sensor that measures an analog value and i want a ICs to convert it to TTL serial ,
because i want to send it afterwards via a bluetooth IC that takes TTL serial as input. I already have a working prototype with a µController but i want something more compact and doesn't need to be programmed. What are the keywords that i should use form my research? thank you
