So I have a small circuit that I made to flash some led's in sync with my music. It's just a signal from my speaker going into the base of my 2N3903 transistor and the ground of the led is being interrupted by the transistor. The circuit works just fine but I was wondering, how and where can I add a capacitor in this circuit to make the lights dim off instead of shut off imeaditly.
Thank you!
  • \$\begingroup\$ I have not tried that yet, I drew up the circuit on a pice of graph paper and took a picture of it and was going to add it but I can't seem to find out how to do that on my phone. Currently not actually near my pc. \$\endgroup\$ – Ben Anderson Aug 13 '15 at 5:15
Well a schematic would be pretty helpful to get you a better answer but have you tried just putting a 10uF capacitor in parallel with the LED? Better yet maybe with a small current limiting series resistor between the positive side of the cap and the diode.
You might be able to put an electrolytic capacitor in between one of the LEDs leads and what it connects to, but probably not both leads. I say an electrolytic capacitor because they usually have higher capacitance, thus a good enough dim time (as opposed to a few millisecond dim time)
