Which will provide longer battery life: 2xAA batteries in series or 4xAAA batteries in series regulated to 3V via a voltage regulator or buck converter?
  • \$\begingroup\$ This can be answered generally in terms of what you have asked, but it would help if we knew the current draw and also the "battery" (they are actually cells) chemistry \$\endgroup\$ – stefandz Aug 15 '15 at 9:00
  • \$\begingroup\$ So the current draw is around 10 mA and I'm using normal alkaline cells. \$\endgroup\$ – David Högberg Aug 15 '15 at 9:03
    \$\begingroup\$ Not the question in your text (hence the comment) but in your title you say 'best'. Cost of AA cells is similar to AAA cells and energy is about half so operating cost will be about double using AAA cells, all other things being equal. \$\endgroup\$ – Spehro Pefhany Aug 15 '15 at 10:25
  • \$\begingroup\$ Agree with Spehro. AAA are for where AA don't fit, like inside an ink-pen voice memo recorder, or flat device that must be thin, or headphones that must be lightweight. Most of the time AA are the better choice due to how much money it'll save the owner in replacement batteries. \$\endgroup\$ – Matt B. Aug 16 '15 at 7:31
  • \$\begingroup\$ Lifetime battery cost can add up to more than the cost of replacing the product with one that uses a different type of batteries. If you don't optimize for cost to operate, your product may wind up in the junk drawer even if it otherwise works fine. Even if it has slightly longer battery life. It matters how much batteries cost at retail - not just wholesale for what you ship with the product. \$\endgroup\$ – Matt B. Aug 16 '15 at 7:34
Synopsis: 4xAAA + a synchronous buck converter for maximum lifetime.
This is a good question as it shows up the advantages and disadvantages of a couple of approaches to power management. The chart below shows a typical set of discharge curves for an alkaline cell.
Typical alkaline cell discharge curve
The brown curve is at 34mA discharge current, which is greater than the 10mA in your scenario, but still broadly applicable. The first thing to note is that the battery only provides 1.5V right at the start of its life - it rapidly falls off. Since you claim to want 3V, this means that (a) there is no overhead for a linear or buck regulator here and (b) your circuit will not last long at all powered by these! If it turns out that you can tolerate voltages lower than 3V you will get a longer run time, but you certainly won't be using either of the regulators you mention. You could use a boost regulator and get more energy out of the cells by discharging them more deeply, but that isn't what you asked about so I am going to steer clear of it for now and come back to it later.
As for 4xAAA - their nominal output voltage would be 6V, so we do have headroom for a converter. A low quiescent current LDO regulator would be the linear choice here. For a 30mA output current (enough for you), 100mV of dropout voltage is not uncommon, so we shall assume that we can operate all the way from 6V down to 3.1V - that is down to 0.78V per cell - so low that it is off the chart below! Efficiency will range from 50% initially up to 96% just before the LDO finally drops out. Input current draw will remain 10mA throughout.
The chart below shows service life for a typical AAA cell (source) at different depths of discharge.
AAA cell service life
Now again, we're working off the graph which isn't great, but we can say for sure that the service life at 10mA discharge current for an acceptable cell voltage of 0.8V is greater than 100 hours. So the question is: would this be greater with a buck converter? In theory, yes, but what about in practice - do quiescent currents and switching losses swamp any theoretical gain?
This chart (taken from here) shows that >90% efficiency is possible for 6V in, 3V out at 10mA current draw.
Buck converter efficiencies, 6V in
Since the dropout voltage of a buck converter is effectively 0 (switching on the pass transistor just acts as a passthrough) we'll be going all the way down to 3V too, which will put us (slightly) deeper into the discharge curve.
So who's the winner? If you really need the full 3V, you'll get most out of an efficiently designed synchronous buck converter powered by 4xAAA cells, followed by the linear.
If you can deal with voltages lower than 3V, the 2xAA cells approach might work for longer than my initial (dismissive) analysis showed - but given the total energy in 4xAAA is about the same as 2xAA and the series + buck combination will allow for deeper discharge, you're always going to be best with the 4xAAA + buck.
    \$\begingroup\$ To the OP: this is also a very good answer. My suggestions are technically not within the solution space provided. But this answer stayed within that solution space and provided very detailed information. Stefandz and I must have answered almost at the same time. \$\endgroup\$ – mkeith Aug 15 '15 at 10:27
2xAA stores a little more energy than 4xAAA. But it is not that simple.
A fresh alkaline battery will put out 1.6V, and discharge down to around 1V or 0.9V over its useful life. So if you go with 2xAA, you will have to use a boost converter to get 3V. Pick one that can operate down to 1.8V Vin. Unfortunately, this is probably your best choice. I know that 3.2V Vin is greater than 3V, and it may seem strange to operate a boost converter under these conditions, but it should be OK for most boost converters.
If you go with 4xAAA, that will give you a maximum voltage of 1.6x4 = 6.4V. You can connect this to an LDO and regulate it down to 3V. But nowadays most of the small cheap LDO's cannot handle 6.4V. they are all designed for USB/lithium battery systems, so the max input voltage is 5.5 or 6V. So you will need to use a more expensive LDO. Might as well just go back to the 2xAA configuration and use the boost converter in that case.
If you could do 3xAA (if that is an acceptable option), then you could use a low cost LDO and still get decent battery life. With a 10 mA load, you would probably get around 200 hours of battery life.
  • \$\begingroup\$ You wouldn't use an LDO for 4xAAA. You'd use a buck converter (switching regulator). Going from 6V down to 3V with an LDO wastes 50% of the batteries in the regulator. \$\endgroup\$ – Tom Carpenter Aug 15 '15 at 15:32
  • \$\begingroup\$ @TomCarpenter, sometimes cost is more important than battery life. And you shouldn't use 1.5V for the efficiency calculation. You should use the average voltage, which is more like 4.8 or so. And my main point is that if you are going to incur the cost of a switcher anyway, you might as swell stick with the AA batteries and do the boost thing because AA batteries have slightly more energy than 2xAAA. \$\endgroup\$ – mkeith Aug 15 '15 at 16:25
  • \$\begingroup\$ ? I don't think I was doing an efficiency calculation, more just pointing out how wasteful it is - even if you use 4.8V, that is still ~40% of the supply gone. And besides simple switchers nowadays are quite cheap. \$\endgroup\$ – Tom Carpenter Aug 15 '15 at 16:53
  • \$\begingroup\$ Most of the stuff I design is for volume production. The cost difference between a switcher and an LDO is around 8 cents, in my experience. LDO is around 6 or 7 cents, and the switcher + inductor is around 15. Sometimes that 8 cents cannot be justified. Maybe your experience is different. The point is that there is a tradeoff between cost and power efficiency that has to be made. \$\endgroup\$ – mkeith Aug 16 '15 at 21:47
