I am currently looking to integrate GSM SIM900 and GPS Module with Atmega32. As atmega32 has 1 UART option, I was just wondering that can I connect these two devices with single UART. I am making a simple GPS tracker which will send a GPS Lats Longs to user mobile whenever a user ask for it.
Does anyone have any idea about this problem, pls share. Thanks
  • \$\begingroup\$ Software / bit-bang UART? \$\endgroup\$ – jippie Aug 16 '15 at 11:52
    \$\begingroup\$ Here is a question with the same problem. \$\endgroup\$ – Bence Kaulics Aug 16 '15 at 18:44
Assuming you don't need to communicate with both devices simultaneously, why not use an analog switch (such as the NLAS4684) to switch TX / RX between the two devices? Tie the two control inputs together and pass to a spare output on the Atmega32 and you can use one pin to select the device you are communicating with.
