I'm looking through USB 3.1 specs and can't find any answer about one simple question.
I'm designing USB Type C to USB 3.0 Female A adapter, which will require USB 3.0 bandwidth (5Gbps) and standard 3.0 supply (900mA@5V). The idea i can't determine - can it be done without special ICs (like TUSB321 or CCG1/2)?
What i'm thinking for now: it can't be done without something like TUSB321 (which determines necessary current through CC). If i'm wrong - i'll be glad to hear it.
Yes all you need in this case is a Rd( Pull down resistor) across CC line.
| improve this answer | |
    \$\begingroup\$ Some links to relevant specifications or example circuits would improve this answer. \$\endgroup\$ – David Oct 26 '15 at 20:29
  • \$\begingroup\$ You can refer USB Type-CTM Cable and Connector Specification Revision 1.1, April 3, 2015 from usb.org/developers/docs/usb_31_102015.zip Also you can refer simplified gist of the specification and other details in amazon.com/gp/product/B014SO7U4W \$\endgroup\$ – RERA Oct 27 '15 at 4:43
