I have a CC3200 LAUNCHPAD and I saw the Code Composer Studio + Energia integration and thought it was sweet. From the tutorials, it looked like it was super easy to use an Energia Sketch in Code Composer. I can import a sketch just fine and I've imported the simple WifiWebClient sketch to try out my environment. When I import the sketch, it also makes a "lpcc3200_core" folder in the tree. When I go to build, that "lpcc3200_core" has errors which are all header file inclusions. The header files that it says are missing are clearly in the project already. I've posted on the TI E2E forum, the Energia forum, and contacted the Energia people directly with no luck. I figured I'd post this here.
EDIT: I messed around with library locations before so here is clean run of the error.
fatal error: cc_types.h: No such file or directory
and once with""
. Anyway, try prepending them withdriverlib/
