I want to implement serial communication into one of my projects, but I'm hesitant to use a serial cable due them them being exceedingly hard to find nowadays. I found an old converter and took it apart to see whats inside it, and to my surprise, they were all components I already own (basically). Just a pic microcontroller (a really old one which I don't own), and a level converter (not the max232 which I have). Are there any tutorials that include code that would explain how to build one of these from scratch?
  • 7
    \$\begingroup\$ Get an FTDI chip and something similar to max232 for level shifting. These two plus couple of capacitors will do the job. No code needed. \$\endgroup\$ – Eugene Sh. Aug 17 '15 at 20:37
  • \$\begingroup\$ Or if you just want a USB port on your board, no level shifting is actually needed, so just FTDI.. \$\endgroup\$ – Eugene Sh. Aug 17 '15 at 20:41
  • \$\begingroup\$ A 1 dollar usb to TTL serial converter would be the best choice for a project. If you really want to go about it, Microchip has a USB to CDC/Serial framework for their usb enabled Pic processors. And there are open source framework/libraries for the same on ATTiny/ATmegas and msp430 and other chips. \$\endgroup\$ – Passerby Aug 17 '15 at 21:06
  • \$\begingroup\$ A serial cable may be hard to find, but easy to build. Get two D-SUB-9 connectors and solder them onto a suitable cable. \$\endgroup\$ – Ariser - reinstate Monica Aug 17 '15 at 21:15
    \$\begingroup\$ 9 pin serial "COM" ports are surprisingly common even today. Modern motherboards will tend have them on a header than out as a connector but they are still there most of the tiem. The cables themselves are easy to find. \$\endgroup\$ – crasic Aug 17 '15 at 21:54
I use this part in a lot of my products. It creates a virtual com port (essentially this chip is what is inside a converter cable but this way your product still has a normal USB connector).
The above is just one example. I'm sure there are other similar parts out there.
| improve this answer | |
  • \$\begingroup\$ You misunderstand. The OP isn't looking for an easy, practical solution. \$\endgroup\$ – Jeanne Pindar Aug 19 '15 at 3:36
  • \$\begingroup\$ I'm not sure if that's true... It said he wanted what's inside a converter to put into what he already called a project. \$\endgroup\$ – Houston Fortney Aug 19 '15 at 9:34
FTDI's DB9-USB modules provide a USB-serial adapter in the same form factor as a conventional DB9 connector, allowing you to place either in the final product in order to meet requirements.
