If you are otherwise comfortable with RF PCB design in that frequency range, then you can buy diodes from MACOM and others that will limit the RF Power.
The simplest are just regular (low-capacitance) diodes back to back. But for GHz limiting you use PIN limiter diodes, which rectify the signal and use that to bias themselves into conduction. They function as power-variable attenuators, they don't just clip the wave.
Usually these diodes conduct at 0.5 V or so, so your limiter will start to limit at +5 dBm and saturate at +15 or so. Limiting to +30 and passing +20 will be much harder.
Limiters also have a maximum rating, for affordable ($100) ones it might be 1 W continuous and 10 W for a few microseconds. 100 W pulse are available for >$1000. More than that and you're on your own.
Limiters still have a finite speed, so they can't clamp a very wide band pulse with a short rise time. They will let through some RF for a nanosecond or two, if the pulse rises quickly enough. Check the datasheet if this might apply to you.
If you're not comfortable designing the boards, look at Mini-circuits, MACOM and other manufacturers for a limiter.
