Can someone help me identify these connectors, I haven't seen them before, tried searching on digikey but there are a lot of connectors, and some of them don't have pictures so it's proving difficult to identify it.
I need both types female and male of the connectors.
And tools that I would need to attach them to wires.
enter image description here enter image description here enter image description here
  • \$\begingroup\$ What kind of device is in the first picture? \$\endgroup\$ Aug 19, 2015 at 9:36
  • \$\begingroup\$ A broader view of the first connector would be more helpful. Also it looks like something you plug and twist, hence a side view wouldn't be unwelcome. \$\endgroup\$
    – K. Rmth
    Aug 19, 2015 at 9:52
  • \$\begingroup\$ I quess that the first connector is some kind of mini-DIN 8 connector. \$\endgroup\$ Aug 19, 2015 at 10:28
  • \$\begingroup\$ It's from a motor device, and sensor 3 wires for the motor and 2 for the sensor. It will be difficult to give a broader view as I can't remove it from the enclosure \$\endgroup\$
    – ilijamt
    Aug 19, 2015 at 17:22
  • \$\begingroup\$ I found a similar cable on AliExpress that has the same connectors. \$\endgroup\$
    – ilijamt
    Aug 20, 2015 at 10:24
The white ones look like Molex 0.062" Connectors to me, the other one is very hard to tell. Download a data sheet and take some measurements, there are other sizes available so check to see if they are the 0.062"s.
Molex 0.062" Product Line
  • \$\begingroup\$ The white ones are Molex 0.062" \$\endgroup\$
    – ilijamt
    Aug 20, 2015 at 19:30
  • \$\begingroup\$ As for the other one I can't find DIN 8 that has the same measurments \$\endgroup\$
    – ilijamt
The black round connector is definitely a TE CPC series connector. Based on the picture it's a size 11-8 panel mount. You can find the compatible plug and correct contacts on the supplied link.
  • \$\begingroup\$ Looks the same. I measured the diameter to about 0.682" which is more or less the same as on the connector which is 0.688". \$\endgroup\$
    – ilijamt
    Aug 20, 2015 at 21:16
  • \$\begingroup\$ I was going to say the same thing. You can find them on Digikey, but OnlineComponents usually has lower prices on connectors. \$\endgroup\$
    – lyndon
    Aug 20, 2015 at 23:58
