I have a state diagram that is consisted of 3 states and in reset it comes to state s0 then if an event happen on start signal goes to state 2 and statye there for 15 clock sycle and then after that goes to state 3 and then back to state s0. My question is that when VHDL coding how could I do the 15 clock delay of state 2. I know that a counter needs to be there but it is not clear for me how to do the VHDL coding. Could any one please give me some help. Thank you
  • \$\begingroup\$ I write a VHDL code for a counter that is a down counter and I have written a process for output logic of the state machine but I dont know how I could relate these two to each other \$\endgroup\$ – user83736 Aug 21 '15 at 13:35
  • \$\begingroup\$ A pure FSM can't have a counter. Counter is FSM itself. If it is counting up to N, it will have N (or N-1) states. This is the theory. \$\endgroup\$ – Eugene Sh. Aug 21 '15 at 13:38
  • \$\begingroup\$ Then I should you 2 FSM for that? \$\endgroup\$ – user83736 Aug 21 '15 at 13:39
    \$\begingroup\$ I though of using one process for the fsm itself and another fsm for the timing which would result in 2 FSM ? \$\endgroup\$ – user83736 Aug 21 '15 at 13:41
  • \$\begingroup\$ Well, you don't have to design it as a pure FSM. As I said, it's a theory. \$\endgroup\$ – Eugene Sh. Aug 21 '15 at 13:42
Assuming you're not doing the "theoretically pure" method of programming a FSM in VHDL, just do something simple like this:
fsmCount: process(clk, reset)
    begin
        if reset = '1' then
            --Reset code here
        elsif(clk'event and clk = '1') then    --on the rising edge of the clock
            case state is
                when s0 =>
                    --VHDL for s0
                when s1 =>
                    --VHDL for s0
                when s2 =>
                    s_counter <= s_counter + 1;    --increment a counting signal
                    if s_counter = CLOCK_DELAY_15_CONSTANT then
                         --do what you want here when you hit your delay
                         s_counter <= '0';
                    else
                         state <= s2;        --if your delay isn't reached, stay in this state
                    end if;
            end case;
    end if;
end process fsmCount;
I'm just answering the state: s2 portion, I'll let you handle the rest of the logic you require in the rest of the FSM.
You will also need to declare some signals and constants in your architecture section:
The variable "state" is an enumeration of the different states you need (i.e.: s0, s1, s2).
Then "s_counter" is some signal of some bits wide that you declare.
"CLOCK_DELAY_15_CONSTANT" is a constant value that you decide is necessary for your desired delay. Which sounds like it's just 15 clock cycles, so it's just 15 in that case.
This is an example, on how a FSM can control a counter. If the second state is entered, the counter counts up until 15, then the FSM goes to the next state. The counter is reset in every other state.
Declarations:
type T_STATE is (ST_IDLE, ST_SECOND, ST_FINISHED);
signal State        : T_STATE    := ST_IDLE;
signal NextState    : T_STATE;
signal Counter_en   : STD_LOGIC;
signal Counter_us   : UNSIGNED(3 downto 0)    := (others => '0');
Logic:
process(Clock)
begin
  if rising_edge(Clock) then
    State  <= NextState;
    if (Counter_en = '0') then
      Counter_us <= (others => '0');
    else
      Counter_us <= Counter_us + 1;
    end if;
  end if;
end process;
process(State, Input1, Counter_us)
begin
  -- default assignments
  NextState     <= State;
  Counter_en    <= '0';
  case State is
    when ST_IDLE =>
      -- do something
    when ST_SECOND =>
      Counter_en    <= '1';
      if (Counter_us = 15) then
        NextState   <= ST_FINISHED;
      end if;
    when ST_FINISHED =>
      -- do something
  end case;
end process;
Is is only one possible example on how FSMs/Counters can interact.
  • \$\begingroup\$ That was really helpful. \$\endgroup\$ – user83736 Aug 21 '15 at 16:46
