I have just a couple of questions...
  1. Is the "male" side the one with the male contacts or the male contact shroud?
  2. I'm also looking for the PNs for a 2 circuit configuration of the housing on the left side of the page. I presume the number in parentheses is the PN for the contact and the left most table at bottom has the PN for the housing.
  • 4
    \$\begingroup\$ male is usually with a pin-type contacts, the female is with receptacle contacts. Pretty intuitive, I would say.. \$\endgroup\$ – Eugene Sh. Aug 21 '15 at 14:16
    \$\begingroup\$ @EugeneSh. is correct. Pins = male, sockets = female. Doesn't matter what the shroud is doing. \$\endgroup\$ – DerStrom8 Aug 21 '15 at 14:18
    \$\begingroup\$ BTW, the google translate from camera on my smartphone is working surprisingly well with this page. \$\endgroup\$ – Eugene Sh. Aug 21 '15 at 14:22
  • \$\begingroup\$ Apparently it's not allowed to post an answer containing Chinese characters. This is going to make it hard to give certain kinds of answers. \$\endgroup\$ – The Photon Aug 21 '15 at 16:01
  • \$\begingroup\$ There are similar alternatives from Molex, Tyco and the other usual suspects. \$\endgroup\$ – Lior Bilia Oct 29 '15 at 20:52
From the top left: "Negative Connecting Clamp".
Middle left: "Negative Connector"
Bottom: "Installation Dimensions/Measurements"
Top Right: "Positive Connector"
Left Table: "Socket", Right Table: "Plug"
Inside the tables, you have "Cable number", "Model Number" and then the dimensions in mm.
