I need help with the following problem:
Find range of resistance R4 and voltage U4 so that the range of current I is $$I \in [-3A,-1A]$$
E=5V, E4=6V, Ig=1A, Ig4=-3A, R1=2ohm, R2=3ohm, R3=5ohm
Firstly, I set current I=-3A. Setting potential V3=0 V, current I23=0.25 A.
Using Kirchhoff's law on node 2 I12=1.25 A. On node 1 I14=1.75 V.
Now potential of nodes are V1=5 V, V2=1.25 V, V3=0 V V4=1.5 V.
With potential of nodes method on node 4, R4=2.09 ohm. Then, U4=-4.5 V.
In my book's solution, it says that R4 starts from 0.22 ohm and U4 starts from -4.5 V.
Could someone check this?
