Can I supply a single appliance using multiple power supplies?
For example if an appliance requires 100 watts of electricity, can I supply it with two power supplies, both of 50 watts?
  • \$\begingroup\$ How do you propose to connect two power supplies to one appliance? It could work, given two identical supplies with specific characteristics, but not with two arbitrary supplies. \$\endgroup\$ – Dave Tweed Aug 22 '15 at 14:27
100 Watt is not electricity but Power.
The answer to your question:
in theory yes
in practice some voltage/current conversion might be needed. It also depends on what devices you're using. How will you make sure equal power is drawn from both supplies ?
