I've found one simple schematics for capacitive sensor on electronics-project-design.com, and implemented it as follows: capacitive touch sensor schematics
The B? is 9v battery. Sorry for the odd-looking schematics: gschem usability is near zero. And the device is NE555, not LM. The plate is ~10x10 cm aluminium foil. Q1 hFE is over 300, if that matters.
At first, I checked with a 'scope at the Q1 collector and 8k resistor instead of led and smaller resistor. And, wow! the plate worked most of the time as a proximity sensor.
Then I decide to try with a led (without the 'scope), and the proximity sensing was there no more. (Needless to say, the circuit is not connected to anything, works on battery, build on a breadboard) But then the thing worked even better as touch sensor... Except for I needed to touch the ground T0 to activate. To be honest, when the plate is connected to the ground, touching R1's open end has the same effect, which is reasonable as the body makes a capacitor with the plate.
Thus, the questions:
1) Does this design have any problems if the logic output will be connected to some other circuit? Should I use optocouplers for instance to prevent noise? update: one problem I found after writing this is that when I switch off the table top lamp, the sensor works no more... Is some kind of oscillator needed after all?
2) Is it possible to turn this into proximity sensor (1 cm distance is enough) or does it make sense to go with ICs like QT113 and the like? Will proximity work outside, where there is no low-freq electric lines noise?
I have not yet decided whether the sensor output will just plainly switch something ON/OFF or whether MCU will be required for more advanced logic. Probably the latter. But for sure there will be two sensors used.
There are so many capacitive sensors design out there, so I chose what seemed simple.
  • \$\begingroup\$ Quick couple of points: 1. I would suggest you use the schematic editor built-in to the question editor - hover over the icons until you see a tooltip saying "Schematic Ctrl-M" - it is the 7th icon from the left. 2. The schematic you have drawn is not the same as the one you linked. Which is it that you are actually asking about - I can't see how the one you have drawn could ever work. \$\endgroup\$
    – stefandz
    Aug 23, 2015 at 18:35
  • \$\begingroup\$ Ah. I forgot to draw that R2 resistor (fixed). Thanks for noticing! Other difference is LED instead of buzzer, some values are slightly different. (Can't spot other differences) Of course, I am asking about my circuit. \$\endgroup\$
    – Roman Susi
    Aug 23, 2015 at 19:08
I am surprised that the circuit stopped working when you added an LED, but that is likely something of an aside in the context of this question.
The 555 is a general purpose timer which has been used to implement a wide variety of other circuits over time. It is very handy, but there is a near-fetishisation of trying to achieve things with the 555 which, although possible, are certainly not optimal solutions.
I'm certain that with enough careful design of the physical sensor electrode layout, tweaking of component values etc. you would be able to get the circuit to do what you want. However, you will not learn a huge amount doing so, and neither will the end result be a system that is robust to environmental changes - for example long-term drift in humidity.
I would strongly recommend using a dedicated capacitive sensing IC for anything other than very simple touch buttons. They implement sophisticated baseline filtering to allow for long-term environmental drift, use advanced detection algorithms and have dedicated onboard hardware to generate drive signals for the electrode - none of which have to be implemented in software. Although some microcontroller manufacturers implement elements of this in their products, none do it so well as the dedicated ICs.
Take a look at breakout boards available from companies such as Adafruit and Sparkfun for easy-to-use solutions. Each will have their own benefits and downsides. Some will be useable without a microcontroller to configure them and interpret readings. Others will require a microcontroller, but generally allow much more adjustability and tweaking. To my mind the learning opportunities with these are far greater too, as you can see the effect of changing a wider variety of operating parameters.
With that in mind - answers to your questions:
1) There should be no issue in connecting the output of the 555 to another high impedance input provided the two circuits share a common ground. If this is not the case then an optoisolator is certainly one useful solution to getting a signal out. By the way - grounding is very important in capacitive sensing solutions, proximity or otherwise. You always need either a localised ground physically close to the sense electrode (for floating battery powered operation) or a good connection to real earth, although this can generally be supplied capacitively even through an isolation transformer or wall power supply with an isolated earth. This document from Texas Instruments covers a lot of the basic principles of capacitive sensing, including ground provision - reading it will help you understand a lot more about the various design compromises that exist in all capsense circuits, be they using a dedicated IC or not.
2) As I previously mentioned, although this is possible, I would strongly recommend you go for a dedicated capacitive sensing IC.
  • \$\begingroup\$ I really liked your answer. It is interesting, that you recommend readymade IC. Some forums on the web state the contrary: dedicated ICs have little added value. Before looking at dedicated ICs, I will try one more solution though - one with oscillator(s), Schmitt triggers and flip-flop. \$\endgroup\$
    – Roman Susi
    Aug 25, 2015 at 18:24
  • \$\begingroup\$ And one more moment (I will update the question): the circuit stopped working when I detached 'scope, not when LED has been added. \$\endgroup\$
    – Roman Susi
    Aug 25, 2015 at 18:26
  • \$\begingroup\$ The scope removal making the circuit stop working makes me think that the scope was providing a real earth ground via its mains plug. Try the circuit again with a wire between the ground node and a real earth source, such as exposed metal on a radiator. With the greatest respect to those on the other forums, specialised ICs add huge value, in the right context. Some are especially well optimised towards proximity detection, and all are far more adjustable than circuits using standard components. I should know - I work with capsense every day ☺ \$\endgroup\$
    – stefandz
    Aug 25, 2015 at 18:53
  • \$\begingroup\$ BTW, added follow-up electronics.stackexchange.com/questions/189916/… trying specialized IC. Could you please take a look? \$\endgroup\$
    – Roman Susi
    Sep 10, 2015 at 18:35
