Sorry for the long question, it's really opinions I seek which is why I felt I needed to explain the scenario and how much I know/don't know. I would really like some input on my design. I am designing a DC/DC SMPS(switch mode power supply) boost converter.
The general advice about DCM(discontinuous conduction mode) in SMPS boost converters is to try and avoid it. This advice is usually backed up by a barrage of equations. Unfortunately I am not very good at Engineering Maths, but if the DCM is anything like the equations, I get the point, I'll stay away :D ! Aside from adjusting switching frequency, increasing the inductance value looks the biggest way to avoid DCM. In my boost converter the output voltage can be varied(it's microcontroller based) and I expect the load to make the input current vary from 10mA(high inductance needed) to 4A(relatively high saturation current needed). I have had some problems in finding an inductor that would fit my specification, I used Digikeys' Parametric search.
Since inductance value is mostly inversely correlated to saturation current, I understand why it may be hard to find my golden inductor. I have found about 8 out of tens of thousands on Digikeys' site, but they are unshielded(which I don't want for this application), large :( and expensive :( .
I understand how DCM works well enough, that the converter enters DCM when the load current is so low that the discharge cycle of the inductor lets the inductor current slip past zero.
So here is my take, since this application is microcontroller based, couldn't one simply just stop the discharge of the inductor when the current nears zero? I know this means distorting the PWM. What I am suggesting is having two microcontroller pins connected to the base of the MOSFET(or gate driver to MOSFET) that controls the inductor charging. One is switched based on the PWM while another simply goes high when inductor current value drops to the microamperes range. I plan to use another MOSFET (Q2) in the inductor discharge path to measure the inductor current. I'll be using the Vds of the MOSFET (Q2) to calculate the inductor current and decide when step in to charge the inductor. So do I get the IEEE prize for SMPS design :D ? Well I doubt it, as while I was learning how to design a boost converter(which I did off the internet thanks to so many kind people), most of the designs I saw used a SMPS controller so I can understand that there wouldn't have been as much flexibility as with a microcontroller based approach because I never saw anyone discuss this.
So my question is, what are your thoughts? I haven't had the opportunity to test it on a breadboard yet, will do soon, but whether it works or not, I want to know if there is something I am missing, or the opinions of anyone on this idea. I am not an experienced circuit designer so I could do with some input.
Thanks for taking the time to read the question. :)
  • \$\begingroup\$ I never really believed in PWM,frequency modulation is much better specially when your choke requirement cannot be met,You could damage your circuit if you go below the minimum prescribed current,also you can connect similar inductors in series keeping an eye on surge currents,remember you dont always need inductance ,capacitor along resistor can mimic inductance in circuit. \$\endgroup\$
    – MaMba
    Aug 25, 2015 at 16:49
  • \$\begingroup\$ Thanks for highlighting that for me! I don't think I ever came across PFM while trying to learn DC/DC converters, and I read many sources! Just took a quick read from a Digikey article and I see how it works. Would look further into it, thanks! \$\endgroup\$
    – user56054
    Aug 25, 2015 at 22:40
Think about this - the only way to stop the "discharge current" is to prematurely ground the transistor in the boost device to start "charging" current thru the inductor - you have no option - to keep the inductor open circuit is to enter DCM and that is what you are trying to avoid.
The cycle for a boost converter (or flyback converter) can be: -
  • Ground the inductor thus current ramps up and inductor stores energy (charge)
  • Un-ground the inductor - energy gets released to the output cap and load (discharge)
  • If inductor can't sustain current into load via diode you enter DCM and basically the inductor becomes open circuit except for the parasitic capacitance of the MOSFET switcher i.e. you get a damped oscillation until...
  • The cycle begins again.
OK, so then what happens (in that cycle) is a tiny little too much energy becomes transferred to the output capacitor and load (during inductor discharge). This causes the output voltage to rise fractionally higher than what it would and, over a period of a few milli seconds, you might exceed the output voltage that is safe for the load. A few seconds later and you have a dead load and a few seconds later you have a dead boost regulator.
OK before you get to this, the control loop would probably have implemented cycle skipping but cycle skipping is noisier than ordinary DCM so why bother?
BTW, going into DCM isn't that bad - the line regulation of the output isn't as good but it's still quite controllable. There isn't much on the web about this but, due to the self-resonance of the inductor and MOSFET drain capacitance, once DCM is entered there is a small oscillating current in the inductor that is asynchronous to the PWM and when the inductor restarts charging it does so at sometimes a slightly positive or negative current. This can cause the noise on a simple controller such as a fixed-on-period controller.
  • \$\begingroup\$ Ok, well I've learnt a few new things! When I built a 3.7v to 30v converter I used a feedback loop to decide when to stop PWM output. That's cycle skipping right? If that's worse than DCM then I guess I may be worrying about nothing as I was able to get 30v satisfactorily. Am I right in: 1. All that is bad about DCM is that it adds ripple noise on the output voltage? 2. When the converter has zero load I'll be in DCM regardless the inductance value? Thanks for the answer Andy, noting what you said about DCM, I think I'll look into it more on a breadboard to see how I can work with it. \$\endgroup\$
    – user56054
    Aug 25, 2015 at 17:54
  • \$\begingroup\$ DCM = a little random ripple. Cycle skipping = less random but bigger ripple. Both (and CM) produce same average voltage. \$\endgroup\$
    Aug 25, 2015 at 19:01
  • \$\begingroup\$ Thanks for that clarification :) I think I'm good to go prototyping with this much I've gained today. Thanks a lot for your help! \$\endgroup\$
    – user56054
    Aug 25, 2015 at 22:42
