I am constructing a signal generator using a kit. Upon soldering it together, I have encountered a problem. The board is marked with two potentiometer slots, identical except for the values named on the board: 50K for the amplitude control and 1K for the offset control. I have two potentiometers, nearly identical. One of them is completely unmarked. The other has B503 etched on the back. How can I tell which one is 50K and which is 1K?
Thanks.
    \$\begingroup\$ Measure them using a Ohm meter. \$\endgroup\$
    – vini_i
    Aug 25 '15 at 19:56
    \$\begingroup\$ Seconding the previous comment, I would also guess that B503 is 50K (50*10^3) \$\endgroup\$
    – Eugene Sh.
    Aug 25 '15 at 19:57
B503 is probably a 50K pot with a 'B' (linear) taper.
But to measure it, just measure the element with a multimeter.
B503 should be \$50\text k\Omega\$, and the other \$1\text k\Omega\$. As stated in comments, measure to confirm.
