I've used this circuit before to do logic level conversion. The diagram is labeled to reflect I2C however I am using it for UART.
Usually my scenarios have been where the low side is 3.3 V and the high side is 5 V, and this circuit has always been fine.
Currently I have a scenario where the low side will be 3.3 V and the high may be 5 V or 3.3 V. Is this circuit still ok in this case?
    \$\begingroup\$ So JP4 could be either 3.3 or 5, and you want to make sure it will work OK in both cases? I believe it will. I would use a BSS138, personally. Lower Vgs(th). Usually when I do this I put a capacitor (not loaded) across source to drain. It can help speedup the signal if the rise and fall times are too slow. \$\endgroup\$
    – user57037
    Aug 26, 2015 at 5:23
  • \$\begingroup\$ thanks for the feedback. i actually got some 2N7002PW for this but i do have a few BSS138's too :) i'll give them both a try. thanks! \$\endgroup\$
    – myte
    Aug 26, 2015 at 7:21
So your circuit is not ok. Possible causes:
  1. Pull-up resistor to 5V is broken, check the soldering joint, pcb track, and jumper too
  2. Mosfet is broken, so it turns ON at Vgs lower than standard Vgs threeshold value
  3. The 3.3v voltage is too high than it should be, so the mosfet ON even if the input 3.3v
