Anybody knows the difference between these RF receivers? I have a project and I am not able to work with RXB12. It is not receiving my transmitter.
  • \$\begingroup\$ Add links to both RX datasheets. I'm not going to search for them myself. \$\endgroup\$
    – user16324
    Aug 27, 2015 at 10:52
The electrical interface of both receivers is identical. If have changed back and forth between both models in a couple of Arduino circuits. The RXB12 is strongly superior in quality. It is a superhet whereas the XY-MK-5V is just a analog resonator combined with an op amp. The RXB is also much better, if there is RF noise due to its better signal filtration.
