We are using libmodbus library to read register values from energy meter EM6400 which supports Modbus over RTU. We are facing the following two issues.
1) We are facing issue with Modbus_read_registers API, this API returns -1 and the error message is “ERROR Connection timed out: select”. After debugging the library, we found this issue is due to the echo of request bytes in the response message. read() API call in _modbus_rtu_recv returns request bytes first followed by response bytes. As a result, length_to_read is calculated in compute_data_length_after_meta() based on the request bytes instead of response bytes(which contains the number of bytes read) and connection timed out issue occurs. We tried to use both 3.0.6 and 3.1.2 libmodbus versions but same issue occurs in both the versions.
2) modbus_rtu_set_serial_mode(ctx, MODBUS_RTU_RS485) returns ‘BAD file descriptor’.
Please confirm if there is any API call missing or any parameter is not set correctly. Please suggest any pointers to resolve these issues.
Our sample code to read register value is as follows.
int main()
modbus_t *ctx;
uint16_t tab_reg[2] = {0,0};
float avgVLL = -1;;
// EMValue *pemVal = new EMValue;
int res = 0;
int rc;
int i;
struct timeval response_timeout;
uint32_t tv_sec = 0;
uint32_t tv_usec = 0;
response_timeout.tv_sec = 5;
response_timeout.tv_usec = 0;
ctx = modbus_new_rtu("/dev/ttyUSB0", 19200, 'E', 8, 1);
if (NULL == ctx)
printf("Unable to create libmodbus context\n");
res = 1;
else
printf("created libmodbus context\n");
modbus_set_debug(ctx, TRUE);
//modbus_set_error_recovery(ctx, MODBUS_ERROR_RECOVERY_LINK |MODBUS_ERROR_RECOVERY_PROTOCOL);
rc = modbus_set_slave(ctx, 1);
printf("modbus_set_slave return: %d\n",rc);
if (rc != 0)
printf("modbus_set_slave: %s \n",modbus_strerror(errno));
/* Commented - Giving 'Bad File Descriptor' issue
rc = modbus_rtu_set_serial_mode(ctx, MODBUS_RTU_RS485);
printf("modbus_rtu_set_serial_mode: %d \n",rc);
if (rc != 0)
printf("modbus_rtu_set_serial_mode: %s \n",modbus_strerror(errno));
// This code is for version 3.0.6
modbus_get_response_timeout(ctx, &response_timeout);
printf("Default response timeout:%ld sec %ld usec \n", response_timeout.tv_sec, response_timeout.tv_usec );
response_timeout.tv_sec = 60;
modbus_set_response_timeout(ctx, &response_timeout);
printf("Set response timeout:%ld sec %ld usec \n", response_timeout.tv_sec, response_timeout.tv_usec );
/* This code is for version 3.1.2
modbus_get_response_timeout(ctx, &tv_sec, &tv_usec);
printf("Default response timeout:%d sec %d usec \n",tv_sec,tv_usec );
tv_sec = 60;
tv_usec = 0;
modbus_set_response_timeout(ctx, tv_sec,tv_usec);
printf("Set response timeout:%d sec %d usec \n",tv_sec,tv_usec );
rc = modbus_connect(ctx);
printf("modbus_connect: %d \n",rc);
if (rc == -1) {
printf("Connection failed: %s\n", modbus_strerror(errno));
res = 1;
rc = modbus_read_registers(ctx, 3908, 2, tab_reg);
printf("modbus_read_registers: %d \n",rc);
if (rc == -1) {
printf("Read registers failed: %s\n", modbus_strerror(errno));
res = 1;
for (i=0; i < 2; i++) {
printf("reg[%d]=%d (0x%X)\n", i, tab_reg[i], tab_reg[i]);
avgVLL = modbus_get_float(tab_reg);
printf("Average Line to Line Voltage = %f\n", avgVLL);
modbus_close(ctx);
modbus_free(ctx);
Output of this sample is as follows:
modbus_set_slave return: 0
modbus_rtu_set_serial_mode: -1
modbus_rtu_set_serial_mode: Bad file descriptor
Default response timeout:0 sec 500000 usec
Set response timeout:60 sec 0 usec
Opening /dev/ttyUSB0 at 19200 bauds (E, 8, 1)
modbus_connect: 0
[01][03][0F][44][00][02][87][0A]
Waiting for a confirmation...
<01><03><0F><44><00><02><87><0A><01><03><04><C4><5F><43><D4><C6><7E>modbus_read_registers: -1
Read registers failed: Connection timed out
reg[0]=0 (0x0)
reg[1]=0 (0x0)
Average Line to Line Voltage = 0.000000
errno
is modified by EVERY system call, so when a modbus function is called, if there is an error indication returned, handle the error immediately, because the defining value will be overlayed by a intervening call to printf() \$\endgroup\$
