I have seen a number of similar questions but no one ever seems to actually answer this question, so let me pose it a different way. Let's suppose I am stuck on a space ship (so I can't go buy some other parts) and I must replace a blown DPDT relay. I have a handful of NPN and PNP transistors, a few resistors and capacitors of various sizes, and some diodes. I have to replace the relay using only the parts I have. For the sake of argument, assume the components I have will handle the same voltage and current as the relay.
What I thought would work is to create a sort of H-bridge using NPNs for two of the switches and PNPs for the other two. That way, when the switch controlling the old relay's coil was on, the NPN circuit would activate, and when the switch was off, the PNP circuit would activate. I added a pull-down resistor to make sure the circuit was grounded when the coil switch was off. I have only tried this in iCircult so far, but it doesn't seem to work. I tried adding some diodes like I have seen in some h-bridge diagrams (even though I don't think they should be necessary for this configuration) and it didn't help.
Here is my example circuit diagram. I'm showing an unknown device in the center of the h-bridge that could represent a DC motor but doesn't have to. I don't want to get into discussion about flyback diodes and inrush current. The important thing is that current flows one direction when the coil switch is on and the other way when it is off. I know I probably need a base resistor in addition to the pull-down but, as a general concept, I don't understand why this doesn't work when I simulate it.
Here is the original circuit with the relay I need to replace:
  • \$\begingroup\$ For a start, your NPN transistors should be on the low side and the PNP transistors should be on the high side. For the next thing you need inverted control signals to the high and low side I think. \$\endgroup\$
    – vicatcu
    Aug 29, 2015 at 17:58
  • \$\begingroup\$ @vicatcu, I need to open one low and one high. How can I do that if I put both NPNs low and both PNPs high. Can you post a diagram so I can see how your suggestion would work? \$\endgroup\$ Aug 29, 2015 at 18:15
  • \$\begingroup\$ you need to place a resistance after switch that will act like a V-I converter,the NPN transistors should be on the low side and the PNP transistors should be on the high(for NPN being connected to +Vcc makes the bjt work in inverted mode) as vicatcu says,you can try using an inverter,on the other side to invert the input. \$\endgroup\$
    – MaMba
    Aug 29, 2015 at 18:54
Your basic problem is PNP1/NPN2. With the bases tied together, you are getting maximum current flow through the two emitter-base junctions from +12 to ground. Any real transistors in this configuration will die instantly.
If you must use BJTs and want to keep your circuit ideas as much as possible, replicate NPN1/PNP2, and use a fifth transistor to invert the base drive signal between the right and left sides of the bridge. Also, you'll need to either use a 12-volt coil voltage or provide a 6th NPN as a level shifter. But be aware that this will not work well, since the NPNs will not get enough base voltage to turn on hard, and you won't get very good performance.
A better idea is something like
You will have noticed, with some frustration, that none of the resistors have values. There's a very good reason for that: you haven't specified your load current requirements. At any rate, Q1 - Q4 are power transistors, able to handle the load current, while Q5 - Q9 are smaller signal transistors able to handle about 1/10 the load current.
  • \$\begingroup\$ Wow, that escalated quickly :-) \$\endgroup\$ Aug 29, 2015 at 22:07
  • \$\begingroup\$ And sorry for not being more specific with the load requirements. I was trying to head off some of that type of discussion that seems to derail other questions of this type. \$\endgroup\$ Aug 29, 2015 at 22:09
Your circuit won't work (simulate) because the BJT Transistors (you have shown) are current controlled devices and when SW1 is open there is no current flowing.
You can have a look at the tutorial here it uses BJTs too.
  • \$\begingroup\$ That is an interesting tutorial but the circuit the describe would definitely not fit into the scenario I laid out. It has 4 inputs and uses a bunch of logic gates. \$\endgroup\$ Aug 30, 2015 at 14:59
