I have a step down 3 phase Delta/Wye transformer. 400 volts on the primary and 208 volts on the secondary. I have about 4 amps per phase on the primary and 13 amps on the secondary.
How is this possible? It should be around 8 amps on the secondary but the amperage has more than tripled. This means that the transformer is generating over 1 KW of power by itself.
Has anyone else seen this?
  • \$\begingroup\$ Can you post a picture of the transformer's rating plate or nameplate? \$\endgroup\$ Sep 1, 2015 at 14:48
  • \$\begingroup\$ Did you measure the actual voltage too? \$\endgroup\$ Sep 1, 2015 at 14:51
  • \$\begingroup\$ No, but it is a 50 KVA Delta/Wye K-13 xfmr. \$\endgroup\$
    – Matt Wells
  • \$\begingroup\$ That is the actual voltage. \$\endgroup\$
    – Matt Wells
    Sep 1, 2015 at 14:52
    \$\begingroup\$ Post a schematic as to how exactly it is hooked up. I will guarantee you though that the transformer is not generating any extra power. \$\endgroup\$
    – R Drast
    Sep 1, 2015 at 15:00
I think the 3-phase input complicates things so the calculation is not the same as for a "normal" (1 phase) transformer.
There's a calculator and some formulas here
If I fill in:
Three phase P = 4.8 kVA
Line to line voltage = 208 V
then I get the 13.3 A
BUT if I select:
Line to neutral voltage = 208 V
I get 7.7 A
So it depends on how you connect the loads to the transformer, see Three-phase power.
Also this might also help you understand.
