I am designing a circuit to protect CMOS inputs from over voltage by using below circuit.
However, if the overvoltage is applied at Vin, the output of the LDO rises accordingly. I designed circuit using LM3480 regulator. and Vin was 24V, with resistor = 1Kohm, that gives LDO sinking current of 19mA if it were to maintain 5V rated output voltage. The back to back diode i used is BAT54SLT1G schottkey barrier diode.
I looked at the datasheet, and in nowhere i can find such parameter that describes output sink current.
Am I supposed to look at other types of regulator such as shunt or switching?
  • \$\begingroup\$ Use a TVS diode. \$\endgroup\$ – Oleksandr R. Sep 2 '15 at 2:29
    \$\begingroup\$ TVS may not be the best choice. First, they are designed to absorb short-lived transients, and are usually in very small packages. Might not be able to dissipate 360 mW indefinitely. Also, the Zener voltage of a TVS may be too high to protect the LDO output. \$\endgroup\$ – mkeith Sep 2 '15 at 3:39
7
Most LDOs can't sink any current, only source.
This is a simplified schematic of an LM317.LM317
The NPN output stage can only source current, it will become reverse biased if it is required to sink current. Other LDOs have PNP output stages but they also can't sink current, probably until the output voltage goes above the input voltage.
If you have a static load on the supply rail (more than 19 mA in your example - say a 220 ohm resistor) then it may not be a problem as that static load will sink the fault load.
The other thing I have done is put a zener across the clamp supply to provide path for the fault current, a 4.7V zener may be appropriate.
Even if you don't have external diodes most CMOS logic devices have diodes just as you have drawn but internal to the device.
Voltage references often have output stages that can source or sink, but they are too expensive to sue in this type of application.
An active clamp such as below may meet your needs, it won't inject any significant current into your supply - the current will pass through the PNP transistor to ground.
Does the input resistor have to be 1K? Can it be higher? That would reduce the current you have to divert.
You could use a shunt regulator, or there are a few LDOs that will sink current (the default is that they will not). For example, the LT1118 and REG1118- there are others.
You can also clamp to a biased Zener or TVS, or use a transistor emitter.
    \$\begingroup\$ A buck regulator that always operates in CCM will also sink current. \$\endgroup\$ – John D Sep 2 '15 at 2:44
Linear regulators are unable to sink current at all, except in degenerate modes; their pass element (a NPN darlington for regular linears, a PNP BJT for LDOs) is unipolar.
LDOs usually have a parasitic diode from the output to the input though, and this can be damaged if the output voltage rises above the input voltage. Putting a high-current schottky diode from the output to the input will protect the regulator, but the best solution is to not let it happen in the first place.
