I want to interface with RPi-Camera to my FPGA bord.
As you can see, http://www.wvshare.com/product/RPi-Camera-B.htm
This camera has a 15pin-ffc cable. But I can't get a ffc cable's interface information of RPi-Camera.
Does anyone knows each pin's infomations of 15pins-ffc? Also does anyone knows the reference site or resference things to interface RPi-Camera with FPGA?
    \$\begingroup\$ There seems to be a datasheet on the product page. Perhaps, the pin information is there. \$\endgroup\$ – Nick Alexeev Sep 2 '15 at 6:59
  • \$\begingroup\$ @Nick Alexeev : I tried to find it with so much time but I can't \$\endgroup\$ – gmotree Sep 2 '15 at 7:54
RPi uses MIPI CSI-2 interface.
Lattice Semi has a good reference design document for the MIPI CSI2-to-CMOS Parallel Sensor Bridge.
  • \$\begingroup\$ But I can't use MIPI. I have to use parallel instead of using MIPI. As I seen specification, There are might some options in there. \$\endgroup\$ – gmotree Sep 2 '15 at 12:11
  • \$\begingroup\$ The Lattice document describes how to convert the CSI-2 interface signals to a parallel bus (6 - 24 bit wide) using their FPGAs. \$\endgroup\$ – Alexxx Sep 2 '15 at 12:57
  • \$\begingroup\$ You can also use this ASIC chip from Toshiba: toshiba.com/taec/components/ProdBrief/… \$\endgroup\$ – Alexxx Sep 2 '15 at 13:27
  • \$\begingroup\$ If yoh don't mind, would you give me a link of the Lattice you have concerned? \$\endgroup\$ – gmotree Sep 2 '15 at 13:36
  • \$\begingroup\$ Google "MIPI CSI2-to-CMOS Parallel Sensor Bridge" \$\endgroup\$ – Alexxx Sep 2 '15 at 14:41
