29
I need to pass high current on some part of my circuit. I used an online PCB track width calculator to see that required track width is about 5mm and minimum clearance is 1mm, which makes it about 7mm width at total just for one track. I need several of these high current carrying tracks on my PCB which will consume too much space to afford.
I am thinking of soldering copper wires on the top side of the PCB which will be parallel to the thin and symbolical tracks on the bottom side. But I would like to know if there is a more professional way of overcoming this problem.
  • \$\begingroup\$ stevenvh's and Olin Lathrop's answers are very-much direct. The same cross-sectional area, with increased-thickness or height, would take lesser width. \$\endgroup\$
    – user107801
    Jul 4, 2016 at 9:13
  • \$\begingroup\$ But what would be the board's characteristics? how much thick or thin board should be chosen? \$\endgroup\$
    – user107801
    Jul 4, 2016 at 9:15
  • \$\begingroup\$ Is there a possibility of bending-up of the board on heating due-to a "bimetallic-strip"-effect? \$\endgroup\$
    – user107801
    Jul 4, 2016 at 9:17
  • \$\begingroup\$ Also another-point, high-current also means requirement of higher-voltage. So, there is higher-chance of Sparking, Leakage, Short-circuit, etc. So, they are need to be prevented. \$\endgroup\$
    – user107801
    Jul 4, 2016 at 9:33
  • \$\begingroup\$ @AlwaysConfused how is there a requirement of higher voltage? If OP is running 5V @ 12A (which would call for ~4.62mm trace @ 2oz), it's 5V... there's no sudden need to increase the voltage. If OP has space to do so at either end, they could boost the voltage at the source and then downconvert at the destination to reduce current requirements... but high current does not, in itself, necessitate high voltage in any meaningful way. \$\endgroup\$
    – Doktor J
    Apr 16, 2019 at 16:03
7 Answers 7
23
High-current PCB bus bars are available from several suppliers, such as:
http://www.espbus.com
and are an ideal solution. A quick search for "PCB bus bars" will yield a number of suppliers.
    \$\begingroup\$ Second link is dead. \$\endgroup\$
    – Bradman175
    Aug 14, 2016 at 1:29
  • \$\begingroup\$ -1, all the links are dead \$\endgroup\$
    – duedl0r
    Aug 5, 2017 at 22:30
  • \$\begingroup\$ One link fixed. \$\endgroup\$ Aug 6, 2017 at 7:15
  • \$\begingroup\$ A search for "busbar" (no space) on the standard supplier sites, such as Digikey (digikey.com/products/en?keywords=busbar ) gives some off-the-shelf products. High volume PCBs use custom busbars (from the suppliers you'll find on Google), but since you are creating the PCB you could design around off-the-shelf parts: busbar rods, busbar terminals, ... \$\endgroup\$
    – Casey
    Apr 22, 2020 at 17:48
32
I haven't seen anybody else mention temperature.
Perhaps you left the default 10 degree rise in the online calculator?
That's pretty conservative. A 20 degree rise isn't that bad in a lot of situations.
And if you aren't running the highest current continuously, it's quite possible even a higher temp rise would be acceptable, since it will have time to cool down between cycles.
    \$\begingroup\$ This is the right answer of this question. How strange no one voted it up. \$\endgroup\$
    – johnfound
    Oct 13, 2013 at 8:24
  • \$\begingroup\$ related: electronics.stackexchange.com/questions/243973/… \$\endgroup\$
    – user107801
    Jul 4, 2016 at 9:26
  • \$\begingroup\$ from Joule's law ; indeed decreased resistance (more-conductance) give-rise to more-heating. H= (const.) * (I^2) * R * t . . . . . ( t is time here) => H= (const.) * (I^2) * (V/I) * t => H= (const.) * I * V * t. ( => H varies directly in-proportion with current I , when you are using a single piece of Conductor). The impact of varying R could be understood only when 2 or more heater will-be kept in series, so the same current will flow through all these resistors. Then the heater with highest resistance ("tightest"-one) produce more heat in comparison to the other heaters. \$\endgroup\$
    – user107801
    Jul 4, 2016 at 9:28
21
The first answer would be to specify thicker copper than the default, which is usually "1 ounce". 2 ounce copper isn't usually that much more money. After that it gets expensive. There is also a limit on how far board houses can go with this. The thickest I've ever heard of is 5 ounce copper.
If this is a one off or low quantity, then leaving the solder mask off the trace and soldering a wire over it is a legitimate thing to do. A #10 copper wire can carry way more current than even a thick PCB trace of reasonable width. Consider how the current has to get onto and off the extra copper wire though. It's easy to solve the bulk conduction problem and forget about the feed points.
    \$\begingroup\$ we used 6 ounce copper on one board, and it wasn't out of the ordinary. If you use >2 ounce copper, you can't use very small traces/spaces on the PCB though. Also it becomes far more difficult to solder through-hole components onto thick copper. \$\endgroup\$
    – Jason S
    Sep 3, 2011 at 18:23
21
Another solution for boards is to make the trace as wide as you can afford (even if it's narrower than calculations, as long as it's not too much so). Make sure the entire trace is NOT masked, then solder-coat the trace, so you have a nice convex bead of solder running the length of the trace. It's probably not the best solution, but I've seen it used in a variety of production electronics, so it can't be that bad (heh).
  • \$\begingroup\$ +1. I've used this technique and did not have any problems, hope won't have, though :) \$\endgroup\$ May 6, 2012 at 17:38
13
If your layout allows it you could place a series of closely spaced filled vias over the length (and width) of the trace. By allowing it I mean that this will of course have its consequences for the bottom layer too. Make the vias as large in diameter as possible, for instance 1mm on a 1.5mm wide trace. Copper filled vias will reduce the trace's resistance best, but they're much more expensive than solder filled vias.
You can also use thicker copper than the standard 35\$\mu\$, like 70\$\mu\$ or even 105\$\mu\$.
    \$\begingroup\$ what about the mechanical consequences of essentially perforating the board? \$\endgroup\$
    – JustJeff
    Sep 1, 2011 at 11:47
    \$\begingroup\$ @JustJeff - FR4 is very stiff material, you can easily mill a several cm long slot in it without weakening it. So unless you plan to have these traces all over the board + mount a heavy transformer I expect no problems here. I've worked with 0.8mm FR4 and that's stiff enough to carry most components, even with a lot of holes. \$\endgroup\$
    – stevenvh
    Sep 1, 2011 at 13:49
  • \$\begingroup\$ also if you are worried about board warping you can add a cross hatch on the top which prevents that. \$\endgroup\$
    – quest49
    Sep 6, 2011 at 23:02
    \$\begingroup\$ Do you have any examples of this? \$\endgroup\$
    – tyblu
    May 6, 2012 at 22:14
  • \$\begingroup\$ @tyblu - not here, but we did it at my previous job to carry 16A from connectors to relays on a relay module for home automation. \$\endgroup\$
    – stevenvh
    May 7, 2012 at 5:23
E-Fab Carries a line of PCB Bus Bars and Stiffeners, our standard products will carry from 16 amps to 128 amps
http://e-fab.com/products/pcb-stiffeners/
With tinning you can decrease the resistance of the the path by 20% to 70% 1 depending on how thick it's soldered on. If you need just a tad more it seems reasonable.
Soldering a copper wire will bring big gains as a standard PCB is 35µm. In comparison with a 1mm and a 2mm copper wire:
A = h * w = 35µm * 1mm = 35 000 µm²
A = h * w = 35µm * 7mm = 245 000 µm² ~1/7 resistance per length
A = r² * pi = (1mm/2)² * pi = 785 398 µm² ~1/23 resistance per length
A = r² * pi = (2mm/2)² * pi = 3 142 000 µm² ~1/90 resistance per length
[1] EEVBLOG Tinning PCB
