24
There are four address spaces in PCI express:
  • Memory Mapped
  • I/O mapped
  • Configuration Space
  • Message
Can anyone please explain significance of each address space, and it's purpose in brief ?
As per my understanding, These all spaces are allocated into RAM (i.e. processor's memory). Configuration space is the space allocated for common set of registers (present in all PCIe devices). Is this space is common between all PCIe devices ? And how it's useful for PCIe functional operation ?
This space contains BAR (base address register). Is this register gets used to specify the address available in PCIe endpoint ?
I am new to the PCIe, and trying to learn it. I am referring the Base specification, But I think it's written for the readers having some prior knowledge of PCI and PCIe.
Also please refer some free online references useful to speed up the understanding of base specification. I understand that whenever any PCIe device attached with root complex, it will be assign with some memory region.
It's been awhile since this was asked, but I hate orphaned questions :)
First, let's over-simplify a modern x86 platform and pretend it has 32-bits of address space from 0x00000000 to 0xFFFFFFFF. We'll ignore all the special / reserved areas, TOLUD (top of lower usable DRAM, Intel parlance) holes, etc. We'll call this system memory map.
Second, PCI Express extends PCI. From a software point of view, they are very, very similar.
I'll jump to your 3rd one -- configuration space -- first. Any addresses that point to configuration space are allocated from the system memory map. A PCI device had a 256 byte configuration space -- this is extended to 4KB for PCI express. This 4KB space consumes memory addresses from the system memory map, but the actual values / bits / contents are generally implemented in registers on the peripheral device. For instance, when you read the Vendor ID or Device ID, the target peripheral device will return the data even though the memory address being used is from the system memory map.
You stated these are "allocated into RAM" -- not true, the actual bits / stateful elements are in the peripheral device. However, they are mapped into the system memory map. Next, you asked if it was a common set of registers across all PCIe devices -- yes and no. The way PCI config space works, there is a pointer at the end of each section that indicates if there is more "stuff" to be read. There's a bare minimum that all PCIe devices have to implement, and then the more advanced devices can implement more. As for how useful it is for functional operation, well, it's mandatory and heavily utilized. :)
Now, your question about BARs (base address registers) is a good space to segue into memory space and I/O space. Being somewhat x86 centric, the specification allows the specification of a BAR size, in addition to the type. This allows a device to request a regular memory-mapped BAR, or a IO space BAR, which eats some of the 4K of I/O space a x86 machine has. You'll notice that on PowerPC machines, I/O space BARs are worthless.
A BAR is basically the device's way to tell the host how much memory it needs, and of what type (discussed above). If I ask for say 1MB of memory-mapped space, the BIOS may assign me address 0x10000000 to 0x10100000. This is not consuming physical RAM, just address space (do you see now why 32-bit systems run into issues with expansion cards like high-end GPUs that have GB of RAM?). Now a memory write / read to say 0x10000004 will be sent to the PCI Express device, and that may be a byte-wide register that connects to LEDs. So if I write 0xFF to physical memory address 0x10000004, that will turn on 8 LEDs. This is the basic premise of memory-mapped I/O.
I/O space behaves similarly, except it operates in a separate memory space, the x86 I/O space. Address 0x3F8 (COM1) exists both in I/O space and memory space and are two different things.
Your last question, messages refer to a new type of interrupt mechanism, message signaled interrupts or MSI for short. Legacy PCI devices had four interrupt pins, INTA, INTB, INTC, INTD. These were generally swizzled among slots such that INTA went to INTA on Slot 0, then INTB on Slot 1, then INTC on Slot 2, INTD on Slot 3, and then back to INTA on Slot 4. The reason for this is that most PCI devices implemented only INTA and by swizzling it, having say three devices, each would end up with their own interrupt signal to the interrupt controller. MSI is simply a way of signaling interrupts using the PCI Express protocol layer, and the PCIe root complex (the host) takes care of interrupting the CPU.
This answer might be too late to help you, but maybe it will help some future Googler / Binger.
Finally, I recommend reading this book from Intel to get a good, detailed introduction to PCIe before you go any further. Another reference would be the Linux Device Drivers, an online ebook from LWN.
  • \$\begingroup\$ The Post was quite helpful. I am very new to PCIe, For Enumeration process to happen (COnfiguration space allocation and mapping ) do we require driver support, or it can be initiated by Os. \$\endgroup\$
    – kamlendra
    Mar 26, 2016 at 6:14
  • \$\begingroup\$ Thanks, glad it was helpful! Generally, on x86 platforms, the BIOS software does some amount of memory allocation based on the configuration space information it parses from the PCI devices. Modern OSes generally accept this memory map as-is, AFAIK, though they too will go through and enumerate devices to load the appropriate drivers. I remember seeing some interesting low-level stuff in Linux that could let you potentially change what the BIOS had assigned. \$\endgroup\$ Mar 26, 2016 at 8:35
  • \$\begingroup\$ Note that only memory marked as pre-fetchable can transfer more than a single DWORD per transaction; all other spaces can transfer only a single DWORD per transaction. The size of a burst is limited to MAX_PAYLOAD_SIZE (discovered during enumeration). \$\endgroup\$ Apr 22, 2016 at 7:35
  • \$\begingroup\$ Hello. I am new to PCI and will like a bit of clarification on your answer. You stated that the 256b / 4k bytes of configuration space is mapped into system memory. From my self tutoring, i thought access to configuration space is handled through a PCI controller which is statically mapped into the system memory. This controller provides a few registers (for device/function identification, offset into address space, result address) that serve as a small interface into the configuration space. So in effect, about only 5 - 10 bytes is statically reserved for the PCI controller. Is this right ??? \$\endgroup\$
    – Cerezo
    Oct 4, 2019 at 22:26
  • \$\begingroup\$ So, when the host(CPU) writes to a register at address 0x10000004 a value 0xFF, the PCI root complex will fetch this data(maybe it was always polling for a data at any address from 0x10000000 to 0x10100000) and will write it at address 0x04 at the endpoint(PCIe device)? Is this understanding correct? \$\endgroup\$
    – AlphaGoku
    Nov 25, 2019 at 4:46
