I am using an dual voltage electric motor of 1.5Hp and RPM of 1750.Dual voltage motor works on 110Vac and 230Vac but with single 60Hz frequency. There is no over load protection built-in on the motor, but we allow the motor to trip if it draws more amperes than required using an ABB over load protection device. How do we learn how much should be limiting Amps drawn by the motor?
For example: Motor running at 230Vac draws 9.5A and 110V draws 16A. If this is the case how do I set the limiting amp rate on an Over load protection. Is it some percentage of over all current drawn at that voltage?
