Getting into BGA's recently if nothing more than necessity as all the 'cool chips' are only today offered that way.
Still, I am missing something I feel essential when it comes to the layout/design/understanding of now layered power/ground planes. SMT alone is pretty straight forward and simple and I feel I gather the concept, but don't yet understand the implementation....
As an example reference a pic from this Lattice BGA layout guide:
Signal planes, fan-out, top and bottom vias are very clear... But, to be honest, I cannot figure out exactly what is 'happening' with the power and ground planes... Or for EX for the power layer there are obviously two domains here [VCCCore and VCCio], which are connected/separated... But obviously no 'traces' otherwise.... I mean are the red and green areas just a 'copper pour' ? and if so why do the vias to the same plane need to overlap ?
There may be other, more complex reasoning behind this, but I feel as if the 'basic' answer ought to be simple, but I am just not 'getting it'... 'seeing it'... (i.e. even as referenced above, well, okay, separate power planes-- Either the trace is inverted in black or there is only a single isolated pin (to the right) in that one domain or I am just really not understanding....
Would appreciate any advice, resources, references to better my understanding.
In these images, everything that's not black is something - either a via drill, a copper trace or pour, or a silkscreen mark. Unfortunately, it seems that the via drills are not displayed in all of the images - namely the power layer - which makes it a bit confusing. The two dark green circles near the center of the chip on the ground layer are two vias connecting to the ground plane. All of the interconnected black circles are clearances between the plane and other signal and power vias that do not connect to the ground plane.
This particular chip requires one ground and two power supplies, vcccore and vccio. Layer 5 gives the best picture of the vias. Mentally scoot this over on top of the power planes and then you can see which pins are connected to the planes and which ones pass through holes in the planes. For example, the group of vias in the lower left corner on layer 5, two of them are connected to vcccore. They also appear to be connected to bypass capacitors on layer 6. For the little group in the center, two pins go to ground, two to vccore, one to vccio, and one is a signal pin of some sort that's routed out on layer 2. I'm sure this would make more sense if you could play around with the layout in the CAD software instead of just looking at some pictures.
Planes are nice because they can act as isolation between the signal layers. Interestingly, it doesn't matter if a plane is power or ground, they both provide the same isolation properties. Large power and ground planes placed close together also provide a small amount of high frequency decoupling. Planes also have lower impedance than traces and as such don't require as much bypassing while also being able to carry quite large currents, which can be required for large ASICs and FPGAs where core supply currents can be 10A or more per chip.
Here is a picture of another BGA footprint with several different copper pours and more obvious vias:
BGA
Image source: http://techdocs.altium.com/display/ADOH/Unused+Pad+Shape+Removal
Many of the vias in that image do not have pads as they are not connected on that particular layer. This provides more clearance for the copper pour to go between the padless holes.
Here is a screenshot of the same PDF file with the vias highlighted in white on all layers:
vias
From this picture, you can plainly see that two vias connect to ground, two connect to vccio, and 4 connect to vccore. You can also see that the two vias that connect to GND pass directly through the vccore and vccio planes without connecting. No blind or buried vias are used here, the vias pass through all 6 layers, all the way from layer 1 on the top of the board to layer 6 on the bottom of the board. You can also see the ground vias that connect the bypass caps on layer 6 to the ground plane, though I did not highlight these vias.
I do note that it is very strange that the chip has 6 power pins but only 2 ground pins. Generally chips (especially in BGA packages) will have at least as many ground pins as power pins.
  • \$\begingroup\$ Dear Alex, I do feel you get what I am saying.. but considering the above why do almost all the 'power vias' (with the exception of very few) also seem to readily 'drop-away' right into the ground plane too ? Further, bottom side one way or another they need to 'go through' for steady power capacitance... I am not in any way (or even using) this chip, but I felt it was a 'simple' example. I haven't the money to afford Altium, honestly, but I will re-examine your thoughts tomorrow. - A \$\endgroup\$
    – Nevermnd
    Sep 5, 2015 at 4:57
    \$\begingroup\$ See edit, I highlighted the vias on all layers to make them more obvious. Also, if you want to screw around with PCB layout on a shoestring, check out kicad. \$\endgroup\$ Sep 5, 2015 at 6:01
    \$\begingroup\$ Thnx. That actually helps a good bit as now the vias are perfectly clear as well as were the 'pads actually hit the plane' (or only the vias themselves were really exposed before). Power/ground seemed like it 'should' be rather simple in the stack-up but somehow I just wasn't 'seeing it' before. And yes, while Altium would be nice.... Kicad is my 'go to' esp after the CERN tuning addition. Thnx. \$\endgroup\$
    – Nevermnd
    Sep 6, 2015 at 14:05
  • \$\begingroup\$ What would we do in free open source tools community without LHC experiments? Thank you, physicists! <3 \$\endgroup\$ Oct 22, 2020 at 20:55
So the green and red areas are planes as you say or you can think of them as copper pours, basically it's copper you are looking at. You can see if you look at the vcc one that it is split into two power domains, the dark line indicating the split.
The dark black holes that seem to be on both layers are in fact the spacing requires around through vias for drilling. In other words in that spot the copper has been removed from the plane so it won't short to the through via as it passes by. A through via could be for say passing a signal from the top to bottom layer.
If you were to line them up on too of one another you would probably see that many of these holes line up but some are only present in one plane or another, that would be indicative of a via connected to that plane.
Hope that makes sense the black is just negative copper removed space.
